Barrel hinges on a turned box?
david
Considering installing barrel hinges on a turned box, because, well...the lid comes off and can be misplaced or worse yet get lost. I know butt hinges need to be placed on the outside edge to allow for clearance when the pivoting part swings open. But a barrel hinge seems to lift up and not be constrained by having clearance issues on the pivoting part. On a circle, however, any mounting distance apart more than an inch or so will have a curving segment that will need to be cleared. Has anyone have any experience installing barrel hinges on a round lid? I guess I could make up a dummy practice piece, but am just lazy, I guess.
Re: Barrel hinges on a turned box?
robo hippy
Well, I haven't seen a barrel hinge on a turned box, but have seen variations of a pin through the lid into the side wall of the box, and a small magnet on the other side. The lid pivots.
robo hippy
david
Thanks, forgot about the pin and magnet solution. Might try that.
Gary clarke
I like the pin and magnet idea, thanks for sharing.
Another suggestion,
Keith Newton
You might think about either tethering it with some sort of nice string or leather.
Also, you can make a loose single or double loop type of hinge, which allows the lid to flip.
Thanks for your input!
