THE WOODRAT IS BACK!
Curved tool rest for bowls
Mike Potts
I have a Jet 16-42 and have stared turning larger bowls. When the bowl gets above 11" by 5" I have a hard time keeping tool marks out of the corner, to much of my gouge hanging over the rest. I'm like the rest of you guys, I hate to spend any more time sanding than I have to. Thought I'd see what others experiences where with these curved tool rest. do they help? any recommendation on which are good/bad.
Thanks for the help
Re: Curved tool rest for bowls
I have 3. I almost never use them. I just adjust my flat rest so it sticks in the bowl. I thought they would be a good idea but I never think to get them out and next thing you know the bowl is done. Maybe it has a lot to do with tool control. I think I needed them years ago but now I just never reach for them.
Steven Antonucci
Mirrors my experience...never use mine
robo hippy
I use curved ones for bowls constantly. Main reason is that you don't have to move your tool rest, and/or banjo nearly as much.
https://www.youtube.com/watch?v=P0uS9gj0Szs
robo hippy
Mike Potts
Reed, just watched the video, well done. the one with the rod on top, what make is that, and where would I find one.
Thanks Mike
robo hippy
Mike,
Those are the Robust tool rests. I am trying to see if it is practical to make one with the drill rod on it that is shaped like the blue cast metal one. The bending is a compound curve, and won't be easy.
http://www.turnrobust.com/Robust_Tool_Rests.html
Brent makes as good of a tool rest as he does a lathe.
robo hippy
On smaller bowls..
david
the straight 12" tool rest that came with my lathe works, but on larger bowls, the 6" reach (almost) is not long enough. This is when I haul out my Oneway curved tool rest. The one for inside of bowls, with the post on one end. Sometimes even this is too short, but it is rare that the Oneway curved rest will not do the job. Use it for outside of bowls too.
Sergio
I have the Oneway one. I have a problem with it. Some vibrations and the fact that the portion the is directly on the post gets in the way of the tool handle when reaching deep near the center. I believe this is a problem with all the curved tool rest since is a matter of geometry, but not with the straight and the S shaped like the blue one in the Robo's video.
barry rockwell
Barry Rockwell
I have the large Robust curved tool rest and find it invaluable when doing the inside of large bowls. I once had a terrible ( read Catastrophic) catch while doing the inside of a very large bowl, just from having too much tool over the straight tool rest. I've gotten around the post end being in the way by using a steeper "bottom feeder" grind when working deep in the bottom. Also very good for shear scraping the inside bottom. I frequently use it for outside curves as well. Wouldn't be comfortable without it in my arsenal.
Philip F Duffy
I have 2 and use them all the time, but then, I am a bit old school and often use scrapers in the finish of bottom of bowls. - - -to each his own -- - Philip
Steve, mirrors are really John's experience
Mike Potts
Thanks guys, I ordered the Robust this morning, I'm sure it will be a great help
ron bauer
I normally use the straight rest when doing outsides and small interior bowls. But when doing a large bowl I use my own design to reach the interior with minimal vibration. The two angled supports work real well. Here are two pix.
This is a 19" bowl that I could not easily reach the center without the tool rest as shown.
The date is wrong. The pix were taken this morning. By the way does anyone have the correct term for the type of color in the grain on this ash bowl? It almost looks like it was melted and ran down the sides. It is pretty neat when finished.
