Walnut carafe/mixed media
mjonesrdg
Walnut carafe form with fabricated brass clasp and leather backer. 7" dia. x 11" tall. Finish is: built-up lacquer, buffed and ren waxed. All C&C's encouraged!
Re: Walnut carafe/mixed media
Woof.....
Richard Jones
Oh, my...........stunning.
Steven Antonucci
+1!
steven antonucci
but I see a future with a broken handle... maybe make a walnut plywood laminate? Too pretty to lose...
S
Wow!
What a finish! Nice form, too. Can you tell us what motivated this piece?
Don Leydens
Don Leydens
Curvy elegance. Love how well the handle flows with the main piece. Man, this is a beauty!
Jennifer Indy.USA
Love this piece! Not only is it a lovely form but it's just so different.
Very cool!
Question on your finishing...
david
The finish is stunning. After you build up your finish, do you go straight to buffing? Or do you hit your built-up finish with something like steel wool or a fine grit sandpaper (which should clog up with the finish material), or do you use something else to dull the finish (assuming it is glossy after the build-up coats) before starting the buffing process?
Re: Question on your finishing...
mjonesrdg
David, the last application of lacquer is sanded with 600, rubbed with 0000 steel wool, buffed with PL compound, buffed with carnuba wax, and finally with Ren. wax.
Inspiration....
mjonesrdg
Ellis,
Inspiration for this piece came from this enameled steel tea pot.
Thanks for the info.
phillip Medghalchi
Beautiful, with a fine curves and finish is stunning. Very well executed.
Yours is MUCH nicer!
