Bowl sanding and Walnut oil
robo hippy
Another instructional clip from me. More to come...
https://www.youtube.com/watch?v=s4Pkr89STGY
robo hippy
robo hippy
robo hippy
Re: Bowl sanding and Walnut oil
James Heaston EC Ohio
Thanks for the tutorial Robo.
Here is something I came across at The Woodworking Show ....
http://grexusa.com/grexusa/prod_type.php5?prod_type=Air%20Hand%20Tools
I was actually looking at the AR368 & asked if it could be slowed down & was showed a screw setting on the handle that you can adjust. Just a thought.
Thanks and a question
DKWalser
I enjoyed the video. Thank you.
Since you use walnut oil for your finish, have you used walnut oil as the lubricant for wet sanding? I tried that as an experiment a few years ago. I find that I I'm using that technique more often than not. I find that the abrasives cut more quickly, the wood is less likely to heat-check, the swarf fills the pores, and there's virtually no dust. Plus, by the time I've worked my way through all the grits, the item is already finished. No need to add another coat of oil. The abrasives cut so much more quickly that I have almost given up power sanding. Of course, I've been turning smaller items, so I don't know how much power sanding I would have been doing anyway.
The one downside is the mess. I cover the bed ways with newspaper and wipe down the lathe carefully after I'm through. It takes a bit more time to clean up compared with simply blowing away the dust. Overall I like the approach and wondered if you had any thoughts on the subject.
About the only time I don't use it is when I'm not planning on using walnut oil as my final finish -- say I'm using a lighter colored wood and I want to retain the wood's brightness.
Re: Thanks and a question
robo hippy
I have tried the oil sanding, and don't think it is an improvement for the way I do things. With my sanding hood, NO DUST escapes, so no problem there. I also do the LDD (half liquid dishwashing detergent, half water for 24 or more hours). It makes a pretty good lubricant (I do totally dry the bowls first, about 7 to 10 days max). The oil is a bit of a mess. The slow speed sanding is a big time saver because the abrasives cut so much better than at high speeds. I figure it is because at slow speeds, the abrasives can really dig in and cut where at high speeds, because of the large surface area, they don't really get a chance to cut. If your drill is throwing a lot of sludge, you are at too high of a speed. When I did oil sand, I found I had to use the coarse grits first, to make sure any tear out and tool marks are gone first because the sludge will fill in any tiny defects, which I didn't like. I do use Vince's discs, and they are the best I have found for fast cutting and durability.
robo hippy
Chuck Jones - West TN
Excellent video Reed. I enjoyed it. Thanks for sharing it.
