Morse code box
Morse code box
Morse code box
This was just an experiment to see what the problems will be in actually doing morse code. This on says "I don't know how to do morse code" Well not really it's just random letters but I wanted to play and see how it looks for a future project.
It is a screw lid box. The joint is 4 lines down. The box is Cherry and the finial is Cocobolo. It's about 5" tall.
Re: Morse code box
Re: Morse code box
phillip Medghalchi
John, you should write the history of the turning in it.
Very nice job. I like it.
Re: Morse code box
Rob Wallace
The problem is.....
Rob Wallace
.....that those of us woodturners who are also ham radio operators will immediately start trying to read what you have written, and when it doesn't make any sense, you will likely frustrate and/or tork-off said amateur radio enthusiast woodturners!!
Interesting idea and nice form. If you know what you want to say, you could simply pass on the text to a ham who could translate it into International Code for you, and then it is just a matter of just copying the dits and dahs ("dots and dashes") onto your piece.
73, DE WA0RW
Rob
Re: Morse code box
Re: The problem is.....
Rob The correct code is what I'm going to do in the final project. I built this to figure out what problems I would have, such as finding the correct code. the biggest problem is I want to spiral it around the piece. Still working on how to do that.
Re: Morse code box
phillip Medghalchi
rob, what if he wants to have it symbolic and not a true message. And, if he does want to have a true message where does he start the message? Then he has to leave a blank area that would represent the beginning of the message. That would not make it too attractive.
John, did you really want to say a message on the vase? and, if yes then where would be the beginning and would it go up on the line like form the bottom to the top or vice versa to relay the message?
The idea is good, however, I have seen that the message is written on a line that goes across the parameter of the object the next line bellow will say a different sentence and so on and so forth.
Re: Morse code box
Rob said "sounds easy"
GaryG in MD
I concur. ex-KØPQW
Re: Morse code box
Chuck Jones - West TN
You missing a letter?
No I'm not a former ham Gary, but I believe you omitted an "H" from your question. ;)
Re: Morse code box
translation not a problem *LINK*
Here is a link to a translator.
Re: Morse code box
Ralph Lindberg
Yup :D
de N7BSN
Re: Morse code box
GaryG in MD
Looks right to me... ??
Re: Morse code box
You are absolutely right...
... my apologies. I missed it.
Re: Morse code box
Re: Morse code box
phillip Medghalchi
John, very nice work.
