REAL MILK PAINT
Off Lathe Sphere decorating Set Up
bowlman
With my cancer surgery only 1 week away, I have been busy getting things ready so that I can keep busy during the 6-8 week recovery period. The surgeon says i will be unable to and not feel like lifting anything over 10 lbs, so, I have been preparing for things I CAN do that are light weight and I can do sitting down.
To that end, I put together this gizmo/jig/set-up that I use to decorate, carve, texture and color spheres. The basic set up is a Woodcut Pro Hold jig with a vacuum feature. I can hook this up to a vacuum pump to hold the sphere steady while I mangle them. The vacuum chuck is home made from poplar, threaded with a Beall Threading Tap. The gasket is fun foam from Michael's.
The short length of hose runs to a ball valve designed for gas, and 2 male fittings from the water plumbing section. I prefer the gas ball valve because of the plastic "T" handle. The lever action ball valves always bite my hand just below the finger next to my thumb on the left hand. I did not use any clamps or teflon tape or pipe dope and the system works great. I did my initial trials on the General big lathe where I do have a vacuum gauge and it was pulling nearly 26 inches of mercury, so I know it works.
This first image is just an overall shot.
The second shot is a close up of the ball valve and short hose and male fittings.
The third picture is a close up showing a sphere already marked out. I do this on the lathe so I can get nice uniform lines all the way around. Then, when I carve or burn by hand, and some "inaccuracy" is introduced, it is not quite as sloppy as if I had done the whole thing free hand. Transalation: I can't draw worth a tinker's dam and I use every means available to make it better.
The last picture is a shot of a sphere already woodburned and colored.
In use, I use to quick clamps to hold this to my work bench. I can sit in a chair or stool, and, using the handles on the Pro Mount, I can position the sphere in any orientation to make the final decoration easier. This also means I can do this without trying to hold a hot woodburning pen in one hand and the sphere in the other. Sure I can only work on one part of the sphere at a time, but a slight adjustment to the ball valve and I can reposition the sphere to expose another area. I have already pencilled in the design on about 50 spheres of various sizes to keep me busy. This week, I will mark out another 50 or so, maybe more, so that I can stay busy.
Tell me what you think!
Re: Off Lathe Sphere decorating Set Up
Don Orr
I think it's an awesome idea and should be good therapy during your recovery. Plannig ahead to keep yourself occupied is a great idea. Hopefully by the time you run out of spheres to decorate you will be feeling well enough to turn some more.
Best of luck with the surgery.
Roger in MO
Roger in Mo
That sure beats watching the "soaps" all day. Good thinking. I suspect you will use the rig after you beat the cancer demon. Blessings. :)
Brad Vietje
Brad Vietje
Great idea and good planning! If you can have some recreation time, you don't have to let cancer thoughts take over your mind. This is a good strategy to stay strong, stay focused, and beat the cancer into submission.
We'll all be pulling for you -- good luck with the surgery.
Safe spinning,
Brad Vietje
Newbury, VT
Dick Keep a pen or pencil handy with lots of paper to jot down ideas. There will probably be times when you just too tired but your brain will probably still be going 100 miles an hours. Making notes will help with all the projects when you do feel better.
I like your vacuum rig. May have to do that to mine.
Question Re: Off Lathe Sphere decorating Set Up
mjonesrdg
Is it necessary for the pump to run continuously while you're decorating? Does opening the valve lose all the vacuum and/or is your pump equipped with sensing switch?
Re: Question Re: Off Lathe Sphere decorating Set U
bowlman
My pump runs all the time. Never heard of a sensing swittch. Heck, my pump didn't even come with and ON/OFF switch. I plugged it in to a power strip dedicated to the pump and a small fan to blow across the pump motor continually while the pump is running. May not be necessary, but I never like my electric motors to get too hot.
Let me know about those sensing swith things.
For others who have asked ... I have been using a set up similar to thius for about 2 months now ... maybe 3. This is the latest iteration of the sphere vacumm jig ... sorta like SVG 2.0 or SVG 3.0(Sphere Vacuum Jig).
Leo Cuellar
Leo Cuellar
A really slick setup.
Best of luck with the surgery!!!
