John Jordan skew: bevel up or bevel down?
david
At the risk of stating the obvious, which way results in a better finish?
david
Re: John Jordan skew: bevel up or bevel down?
John Jordan
David, its not a skew, but a shear scraper. The bevel goes down and does NOT rub. A burr is raised on the edge with a slip stone and the edge is pulled along. This is after you have gotten good cuts with your bowl gouge-it allows subtle refinement of the shape, and makes the surface very smooth.
If you go to my website, there's a couple of articles on hollow turning that have pictures and descriptions of this.
John
Thanks, John!
david
I stand corrected on the nomenclature. Will check out those tips. Please give my regards to Vicky.
Re: Thanks, John!
John Jordan
You are welcome, and will send your regards to the wife.
JJ
shear scraping video *LINK*
About 5 minutes in I show how I use John's shear scraper. Hope this helps.
http://www.youtube.com/watch?v=7oeiVQLeOd4
Re: shear scraping video
Jim Breeden
Thanks for the link Mr. Lucas. I added this to my favorites.
phillip Medghalchi
John, the sound is very ow and seems like your mic. wasn't working. However, appreciate what you wee trying to show. I hope you can make another one with a better sound.
Working on the sound part
Just waiting for warmer weather to make a few more videos. Just can't do those when my shop is freezing.
Well done, Mr. Lucas!
robo hippy
I compare scraping cut vs shear scraping cut to speed bumps in the parking lots. If you hit them square on, it is a pretty big bump. If you hit them at a 45 degree angle, it stretches the bump way out and it is much smoother. The higher angle of a shear scrape/cut does a much better job of gently lifting the fibers up as you cut. I do prefer a scraper for the shear cuts as you can see it cutting where with a gouge, it is rolled over to the point that the part cutting is covered from view. I almost never use negative rake scrapers. Only exception is on end grain. With the CBN wheels, you can raise a great burr, with no need to burnish or hone a burr. They are generally much more durable when compared to a honed burr. Nice clip John.
robo hippy
