Dale,
GaryG in MD
If you don't want to get a single "fancy" photo processing program (I use Paint Shop Pro, but there are MANY others out there, some free), and want to stick with "small, easy" programs, I would suggest a two-step procedure for you.
1) For your light-duty processing, you can't beat Irfanview. We've talked about this before here. Many people recommend it. I have used it as my main "display" program for many years. It will do a fair amount of processing for you, including some automated histogram adjustment and easy buttons to fit photos to the screen or to other physical sizes. It does not, however, have a simple button that lets you pick file size. This has been discussed here before recently. So if you want to do some light processing, use Irfanview. It's free and very easy to use. Then...
2) After you get the image you want from Irfan, to create a file size appropriate for WC or other online uses, simply run that file through one of the simple, free programs that people have already recommended here for doing that.
It's just as simple to do it with two programs as it is with one. NBD.
...GG
