I'm looking for some advice. Years ago, I bought the original Trend Airshield, used it for about a year, wasn't completely satisfied with the airflow, so I sold it and bought a 3M Airstream AS-400 helmet. I've used this now for about 10 years and it is starting to get tired. When I turn it on now the motor makes some noise for a while. The repair on the Airstream is going to be pricey. So, I am wondering if you guys out there who have the Airshield Pro like the product and would you buy it again?
I have had one for 2-3 years and use it constantly. I would probably buy another one if something happened to this one. There have been times when I have lusted for an Airstream but a second look at the price difference cures that problem.
The Trend Airshield Pro seems a little cumbersome to get on and off, but I no longer have to have a wardrobe assistant to accomplish it. Just takes some getting used to. That's about the only gripe I have with it except I'd rather not have to wear one of any type.
I have read a lot about battery problems, which I think comes down to the fact that the charger doesn't have enough intelligence to shut off when the battery is fully charged. I have two batteries and I notice they don't hold a charge as long as they once did. Replacement batteries from Trend are expensive. There is a two step fix for the replacement cost and the charger. It was posted on SMC IIRC and I could dig it out I think. I have already bought the cheaper replacement batteries (~$24 for both sets) and the smart charger (small bucks). I just haven't taken the time to convert over yet. It's all pretty straight forward.
I used the 3M Raycor until it died then the AS Trend old version. Bought the Pro and have used it for several years. I have a small head (although SHE constantly says otherwise) and put some padding at the top so that it fits well. I like the balance and the air flow. I rigged up a battery charger and my batteries are now holding charge for 8 hours at least. The Pro allows you to charge the battery in the helmet which is nice but I think (with absolutely no proof) maybe the wiring and electronics might have an effect on the batteries when charged that way. I would recommend the Pro without any reservation. My 2 cents. Darryl
I have had the Trend Airshield Pro for about 3 years. I used to get sinus infections and such, but now since using one, I have only had one in that time period, and that was because I was not paying enough attention and was using dirty filters. If you change out your filters this unit does a great job and I have 3 batteries........if you do not allow them to stay plugged in more than about 10 hours at a time, then you will not likely have issues with losing battery life.
A smart charger would be a good thing........I think I will try to find an appropriate one for my unit, but all my batteries are doing fine. I highly recommend the Trend Pro!
