ADVERTISE HERE - FREE TRIAL
Quick, easy, cheap (my three faves) club project
Steven Antonucci
steven antonucci
If you look in the catalogs, the sanding pads are usually $12-15 each. Here is what I do instead:
You will need:
1/4" rod (~2" long), which can be just a 1/4" bolt with the head sawn off
a scrap of wood
a hot glue gun
some kind of foam padding (beer coozie from craft store or old flip flops)
industrial hook and look (hook only)
If you are starting with a bolt, leave the head on for now. Let's assume that we're making a 2.5" pad. Take your scrap of wood, and draw a 3" circle with a compass. Drill a 1/4" hole in the middle, about 1/2" deep (by eye is fine, as close to plumb as possible). Use a wrench to wind in the bolt. If you are just using a rod, you can set it with CA or epoxy. Feel free to use either with the bolt, too.
Once the epoxy/CA has set, take the rod with the wooden disc to the lathe and put it in the headstock in a drill chuck. Using a spindle gouge, true up the circle and faces. When you are finished, everything should run smoothly. On the front surface that the foam pad will be glued, a slight hollow will allow you to put in a little more hot glue (~1/32").
Draw another 3" circle on your foam pad, and cut it out with scissors. Hot glue the pad to the disc so that it had some overhang around the entire surface. I clamp it in a bench vise, compressing the foam until the hot glue sets.
Lastly, the hook and loop (hook only) needs to be applied. I found some at a big box store that was labeled "Industrial", and it was adhesive backed. If you cannot find it, you can hot glue as you did with the foam. The stuff I used was only 2" wide, so I applied it to the left side of the pad, and cut it with scissors, and then came back with the other side and did the same thing.
Cost per:
bolt: $.25
pad: $1.00 (get 10 out of it?)
H&L: $2.00/ft (get 5-6 out of it)
Time to complete: 15 minutes?
We're going to be "assembly line" working on these and a few other projects as a club in the spring, so I think we'll et the cost to around $1/ea. The ones that I made 8 years ago still handle all of my sanding. You can make as many as you want in different sizes or foam densities.
Hope this has been useful.
Steven
Re: Quick, easy, cheap (my three faves) club project
One more thing......
I have been wanting some with hex shafts with the quick connect ring. As I was looking at your project it occurred to me I might be able to find some abandoned in my shop and use those. Things like worn out driver bits would work nicely. I have had a bunch of bits that wore out or failed over the years and I threw them away. (My pack rat gene is twitching.) What I have wanted to to do is have a set of sanding disks with one for each grit and then use the quick connect to switch from on to the other.
The hot melt glue holds up? I would have thought the heat would release it.
barry rockwell
Re: One more thing......
Barry Rockwell
Steve, I went to an engine rebuilding shop and got a bucket full of old engine valves of various sizes and lengths for making the sanding mandrels. Cut to desired length and works perfectly.
Steven Antonucci
On hot melt and metal sourcing...
steven antonucci
Yes, hot melt holds up. Admirably well. In fact, I suspect that the temperatures required to melt it are significantly higher than you should ever see sanding? I used to use double stick tape, but I had issues with the adhesive softening, the pad slipping, and leaving a sticky mess on the bowl. No issues with hot melt.
As far as rod sourcing, any 1/4" rod will do. I've considered lopping off the flutes on old drill bits, but I almost always find some rod laying around. you can scuff it up a bit, or just drill your hole a little smaller. I'm not sure it matters, but since I've never had one come off the wood on me. The key is to turn it round after you've attached it, since it will always run true if you follow this procedure. I am sure there is a machinist somewhere that could drill an accurate hole, but it isn't me...
S
Use allen wrenches for hex shafts
Chuck Jones - West TN
I'm missing something here...
...besides a few brain cells. I'm so confused I'm not sure how to state the question.
Assuming you intend to use sanding discs on the facing
what holds the discs to the foam?
why the hook and loop on the edge?
Assuming you are going to use sanding strips on the edge
where do you find hook and loop sanding strips?
what would you use it for?
why the foam on the facing?
Steven Antonucci
Photographic clarity
steven antonucci
If you look at the picture, the white on the right face is the "hook" part of the velcro. The sanding disks I use have the "loop" (fuzzy) part on the back. This goes in an air powered right angle sander that I power with a compressor.
You can change sanding disks by peeling off the grit and replacing it with another grit or a new pad. It is much faster to replace pads than it is to replace the whole assembly. I can peel off a pad, blow the pad and the bowl with the nozzle, and get back to sanding in about 20 seconds.
There is no abrasive on the outer purple surface, although there is nothing really stopping you from adapting this method to include small drums or balls.
Hope that helps.
Steve
Brad Vietje
Re: I'm missing something here...
Brad Vietje
Chuck,
The foam is glued to the wood backing disc, and the hook & loop material is hot-glued to the foam, so these would work for power sanding just like the $15 ones from the turning catalogs.
Anyone know of good sources for thick/soft foam? Multiple layers of one kind?
Safe spinning,
Brad Vietje
Newbury, VT
Steven Antonucci
Beer coozies, flip flops, garden mats
steven antonucci
all can be had at thrift stores for next to nothing... or your local Michael's craft store.
Nothing to make me believe I couldn't hot glue one layer to another, either...
Steve
That helps, thanks
I didn't realize the white surface was hook/loop material. I still don't understand why you have the hook/loop material on the sides (Purple strip) but I understand basically what you are doing.
I pay $9 plus shipping for the backup pads I buy and they have lasted quite well, but this would be a good way to have some extras at a low cost.
Steven Antonucci
the purple is just foam
Steven Antonucci
Nothing but a bit of purple craft foam. It is purple because it was either purple or aqua, so I picked purple. It is one of those things you stuff a beer can in to keep it cold and your hand from freezing.
The white Velcro is adhesive backed. The foam is hot glued to the wood, which is white oak, but that doesn't matter. Everything gets turned to round at 1500 rpm after it gets put together. I use a detail gouge.
S
Re: On hot melt and metal sourcing...
gary jarvis
I like to use the long screwdriver bits for mandrel. Then you can use a speed bit. Each time I change grits I change to a new mandrel. The cost is a little higher for the bits. It cost almost 30 cents apiece buying them at the local Harbor Freight.
Ah! Ha!  Good use for HF
I don't buy much stuff at Harbor Freight, but this would be good.
I like the idea of having a mandrel for each grit. If you use a quick release chuck you can snap one out and the next one in in a second. Make a rack for the various grits and then change mandrels between grits. This gives time for the mandrels to cool down if they have heated and it also avoids pealing the paper off and re-installing it over and over. I find the paper gets really well seated and I have to be careful not to peal the Velcro off the foam with the paper. I have to reglue the edges once in a while. Also, its easier to keep up with the mandrels and keep them in order than it is to keep up with individual pieces of sandpaper. They tend to float around and get sucked up in the dust collector and they tend to get crud on the back of them. If you get sawdust on them you have to clean them before re-installing them. And, sometimes the Loop part wears out or does not hold up well to being removed and re-installed. Having multiple mandrels wins all the way around.
boy prices have gone up-but not too bad *LINK*
The best thing I ever did was to bite the bullet and buy a sanding mandrel for each grit of sandpaper I use. I'm pretty sure they were $5.95 back when I did it. Seemed like a lot of money to me but I was tired of tearing off the velcro or ripping the foam when I replaced the grits. It was about $2.50 for replacement Velcro also.
Now the only time I replace the grit is when it wears out. After 10 years I still have all of the original sanding mandrels with original velcro. I have maybe 2 that the foam in the middle is starting to tear.
With the new keyless chucks in only takes a second to change grits. I did have to scrounge around to find a plastic bin to hold all the mandrels and sandpaper but it didn't take too long and I have all the supplies I need right at hand and it's easy to transport.
I went through all my catalogs and couple of online catalogs and prices range from $7.95 to $26.95. I like Vinces 2" heavy duty sanding pads. They are tapered so you can reach right up to the foot or shoulder or sharp detail edges. His velcro also holds up extremely well.
Of course it's nice to build your own and I have built a few but since my original ones hold up so well I just haven't pursued it very far.
Thanks for posting this Steve.
http://vinceswoodnwonders.com/back-up-pads/
Steven Antonucci
Keyless chuck...  electric powered?
steven antonucci
Or do you have an air powered keyless? I would be interested in multiple mandrels if there was an air powered option with keyless...
just wondering...
FWIW... industrial strength velcro is probably overkill. Cheap H&L worked fine, but the industrial stuff is almost too strong. I use Vince's pads, and it takes two hands to get them off...
Ric Taylor
Re: Keyless chuck...  electric powered?
Ric Taylor
I have an electric angle-head drill with a keyless chuck that I bought from The Sanding Glove that I use for sanding. It works great for me, and I love the keyless chuck.
Ric
Steve Worcester.
While I would love for you to buy a mandrel for me, I would look at using Velcro from the fabric store that doesn't have a glue back, and using solvent-based contact cement to glue the Velcro to the foam. You will have more flexibility between the foam and the Velcro .
