posting pics
posting pics
posting pics
Roger Chandler
Ellis.......as far as I can tell, I am a registered user. I have not been able to post pics for a while. when the box pops up it gives me an option for a url address, but not my computer. A couple of times I have also tried to post a pic from a post on another forum by entering the url address there.......still no go.
I used to be able to post both ways, but in the last several months it is not working. I wonder is somewhere there is a glitch associated with my being a registered user, or if something else has changed.
I appreciate this site, and enjoy coming here, but these issues have lessened by visits, and I was wondering if we could find a way to get this back as it used to be? Any helpful input would be appreciated!
Re: posting pics
Roger,
GaryG in MD
When you Post a new message, right above the text box, you should see:
"Upload embedded file:" followed by a Browse button.
Just hit 'Browse' and it will take you anywhere on your computer you want to go to get your image. ...GG
Re: posting pics
Re: Roger,
ron bauer
As long as we are talking photos.... and I hesitate to say this but I have yet to figure out how to get a photo to be less than 100K bytes. I have used a generic program that was resident on my computer called "Paint" and have some ablity to resize but not enough to get below the 100k threshold for uploading. Does it take a software program? or can it be done by a neanderthal like me??? R.
Re: posting pics
Re: Roger,
Dwight Rutherford
I still struggle with on/off. Simple/Resize is free and works for me.
Re: posting pics
Ron,
GaryG in MD
There are many free programs you can download that will permit you to control the physical size and computer storage size of your images independently. The trick is to shrink the file size without making the physical size small. Just Google "free photo resize" and pick one that looks good. Just make sure it permits you to adjust the file size independently of the image size. ...GG
Re: posting pics
Re: posting pics
phillip Medghalchi
Roger, here is free program /that I use:
http://www.irfanview.com/
Re: posting pics
Phillip,  I don't think so...
GaryG in MD
I use Irfanview too. Love it. It's my go-to viewer, and I even use it for simple processing.
BUT
It doesn't do what he needs. At least I don't think the version I'm using does.
And I tried first because I wanted to recommend it to him.
Irfan will let you shrink pix physically, but NOT the file size while maintaining the image size. At least that's my experience.
If I take a pic that's about, say, 6" x 8" (a good size for our application) and want to reduce it to, say 80kB, I can't do it with Irfan. If you can, please let me know how. (I use a very old version of PaintShop Pro 7.)
If not, then we're going to have to let Roger get a different program from the Web.
...GG
Re: posting pics
Chuck Jones - West TN
Try FastStone *LINK*
Over the years I've messed with dozens of free photo manipulating packages and this one is pretty darned good. The interface is a little different and takes a few minutes to get comfortable with it, but it's worth the effort.
FastStone
Re: posting pics
Re: Roger,
Roger Chandler
Gary.........that is the problem..........I do not get an "upload embedded file" box......or any other type of indication of an imbedded file upload. I do get a "optional Image URL" box for internet images, but I have even tried that on 3 different occasions and it does not work.
I don't understand why? I know I am registered because I got an email about these replies for this thread.
Re: posting pics
Re: Roger,
richiecroce
I too ,would like to post a photo but cant get it to work. All I get is; If its on the internet, provide its URL address.
Gave up trying, totally frustrated
Re: posting pics
Simple solution
Our system uses your registration information to decide that you are a recognized user. I can see by the fact that your name is in black (instead of blue, underlined) that there is some problem with your identification. And, sure enough, you are registered with the e-mail address of 300mag@adelphia.net, yet you're posting with another e-mail address. So, our system thinks you are not Roger Chandler.
What you need to do is to go to Set Preferences and change your e-mail address to the one you prefer, and then save the changes.
Our software is rock solid and only here to protect registered users.
Let me know if you have any questions or problems getting back in order.
Re: posting pics
Image size vs. File size (link)
Doc Green
A very brief explanation of the difference between image size and file size is given in this article:
http://www.docgreenwoodturner.com/photosoft4.html
The basic idea behind JPEG compression is that the image is divided into square blocks, 8 pixels on a side. Then, for each block, the data is mathematically transformed in such a manner that fine detail can be eliminated easily to achieve the amount of compression (reduction of file size) desired.
An analogy is an article written for a newspaper. The big ideas come first. The details come further down the page with the less important being farther down. Then, an editor can shorten the article by simply cutting off the details at the end.
For a JPEG image, the physical size on the screen is determined by the size of the image in pixels, like 800 pixels wide by 600 pixels high.
Then, the image is divided into blocks, as stated above.
Finally, the compression is achieved by eliminating as much of the fine detail (for each block) as is required to reduce the file size to an acceptable level. (Like the editor cutting off the bottom of the column.)
What this means: For a particular picture and a certain file size requirement...
You can have a big image (a lot of blocks) with not much detail per block, or,
You can have a small image (not many blocks) with a lot of detail per block.
Therefore, simply making an image smaller does not necessarily give the reduction in file size you may need (until the image becomes so small you can hardly see it).
I hope this helps clear up some of the confusion. It's not exactly simple, as you well know. ~Doc
Re: posting pics
Resizing Photos
Yes, you need an application, or at least a utility, to resize photos. We're not set up to receive your large camera images and reduce them for you. I wish I could make that happen. Meanwhile, there are countless free programs you can download and use to reduce your own photos. Some are mentioned in our FAQs and others have been discussed here many times over the years. Rather than recommend one, I can only urge you to Google them, pick one, and start using it. You don't need to learn a fancy program, but you shouldn't have any trouble with a simple utility to resize images.
Our 100Kb file limit is configurable, that is, I can change it at will. I could make it 2Mb, and your average camera image file would still be larger. On the other hand, a 40Kb file can have more than enough detail for our messageboards, as you can see in this picture, so 100Kb is plenty.
The idea is to reduce the amount of storage and bandwidth on our servers, and to make files accessible to people who still have low connection rates. At this point in time, with generally higher bandwidth everywhere, we could probably increase the filesize limit, but even making it 1000% larger wouldn't accommodate typical camera images.
Please contact me directly if you need more help with this.
Re: posting pics
Re: Phillip,  I don't think so...
phillip Medghalchi
well, I made you a tutorial, but it's 480 KB, and I have to figure out how to up load it now.
Gary, and Roger, check your emails I sent you the tutorial for the Irfan view as how I do it.
Re: posting pics
Phillip, Sorry, but, no, that doesn't work
GaryG in MD
I appreciate the time you took to make that example, but it only works for the photo you chose because it's got a large aspect ratio and is quite small at 640x283, and it appears that it was already partly compressed in your camera.
With all due respect, you are missing the point about the difference between image size and file size.
Please read Doc Green's explanation.
Irfanview does NOT adjust file size independently of image size.
THAT is the function that is required to make an image large on the screen but small in terms of storage space.
I'm using an older version of Irfan -- I guess it's time I updated, but that doesn't matter for this discussion because I looked at what you did, and it's no different from what I can do with mine.
I do not compress in my camera. I have processed a standard image from my camera in your way and set the image size in Irfan to two different sizes. See here:
You can see that for the two physical image sizes I selected, 800x600 and 640x480 (sizes with tick boxes in Irfan), my storage file sizes are 443kB and 312kB, respectively. These are far too large for WoodCentral.
If I use a program that works with the JPEG file structure, as explained by Doc Green, I can make these images any file size I want, as small as I want, and maintain the same screen image size. There are plenty of free programs available that will do that. But Irfan is NOT one of them.
As I say, I use Irfan as my prime viewer for all jpg's, and I love it, but it does not have the capability to alter file size independently from image size.
Thanks again for your time on this. ...GG
Re: posting pics
please see Ellis' explanation
GaryG in MD
You were not registered properly.
As soon as you take care of that, you'll be fine.
The way Ellis controls the board is to make sure we're "real" people.
It's worth the effort.
If you were ever on some of the old boards without controls, you will know why!
Now let's see some photos! Go for it!
...GG
Re: posting pics
Spell your username correctly
Richie, the name you registered is "richie croce", not "richiecroce". Use the Set Preferences dialog to correct your username to the one you registered in your profile. This resets your WoodCentral cookie and the system will recognize you.
Re: posting pics
Re: Try FastStone
Philip Duffy
WARNING; Chuck, When I downloaded the suggest program I received 6 invasive programs that completely corrupted my laptop!! It also cut my access to my WIFI. I would stay away from that site forever! Philip
Re: posting pics
richie croce
Re: Spell your username correctly
richie croce
Finally!!! IT WORKS :) :) :)
Re: posting pics
Okay, so let's see some pictures
Re: posting pics
Re: Simple solution
Roger Chandler
Thank you Ellis! That is probably the issue.........the email I had is now changed and although I still get email from that old server, it is problematic in many ways. The old one seems to be powered by roadrunner because it was sold to them after the adelphia was bought out.......lots of spam, scams and other issues with it now. I will set new preferences per your advice!
Re: posting pics
Re: Simple solution
Roger Chandler
Okay.......where is the set preferences option located?
Re: posting pics
Re: Image size vs. File size (link)
Roger Chandler
I use Faststone and like the product.......fairly intuitive to use.
Re: posting pics
Top of Turning Index page
...in the gray navigation bar, right next to where you clicked Post New to post a new message.
Re: posting pics
Re: Top of Turning Index page
Roger Chandler
Thanks Ellis........I found it a little earlier, and updated.........I think all is well at this point!
