Sphere jig on a 24" riser.
david
Contemplating a project that will require spheres with a nice appearance, so I purchased a Carter Perfect Sphere jig with a 24"/25" riser post as my Vicmarc VL300 has a 24" swing. The riser posts are purchased separately to fit different lathes. After assembling the unit, the cutter seems to be 3/16" above the center point of the swing. The cutting unit can be adjusted higher with a stop collar on a narrowed portion of the riser post, but cannot be adjusted any lower. With this kind of runout, a nub is left at the end of the turned sphere. Not a total disaster, but with a robust piece of equipment like this, it seems like something is wrong here. From what I can tell, the riser post is at least 1/4" too tall. Is there any body out there having the same issues?
