8" Grinder Wheel
8" Grinder Wheel
8" Grinder Wheel
Joe Pack
I managed to get a catch on one of my grinder wheels and jerked a chip from the middle of the wheel. There is also a small crack leading vertically out of the chip. It is going to take a bit of dressing to grind down to the bottom of the chip...probably 1/4 inch or more, then I have to examine the wheel for the crack (my 10x geologist's loop comes in handy!).
I may just end up replacing the wheel, but I'm not sure what to replace it with. The damaged wheel is a white Norton 100 grit that, except for my carelessness, has served me well, but I have read about the Norton blue 3x K grade wheels (I-grade being too soft and easily grooved according to reviews), as well as references to some other brand of green stones. Other than the advertisement info, I really don't know much about the different wheels except that grey is for lawnmower blades, not skews.
What do you have on your grinder? What would you buy if buying new?
Re: 8" Grinder Wheel
Bill Blasic
Bill Blasic
Joe,
If you can afford it I would got to the CBN wheel in 180 grit for sharpening There is also an 80 grit wheel available. Expensive but worth every penny.
Bill
The green stones are for sharpening carbide you don't need that. Go with the Norton. Pull the wheel you have off and do a "ring" test. Put it on a dowel and tap on it with the handle of one of your gouges. It should sort of ring. If it goes thunk throw it out. I don't think you can accurately look at it and tell if it might explode.
I'm with Bill I do like the CBN but of course they cost about 4 or 5 times what a Norton wheel costs.
Chuck Jones - West TN
Now have:
D-way 180 grit CBN
Norton 80 grit Blue SG
Next time:
D-way 180 grit CBN
Might have to get the Norton 3x because I just noticed a couple suppliers aren't listing the SG any more. I couldn't prove that the SG is worth twice the cost of the 3x, but because of stubbornness and age when I get something that works I'm resistant to change. :D
Bill Howatt
I used to use the white wheels but have switched to a Norton 3x blue and find it much better for turning tools. I still have the original, finer-grit gray wheel on the other side and use it for scrapers. I keep it dressed (well, usually) and when it wears down some more will get another blue.
I strongly suggest you follow John Lucas' advice about doing the ring test before doing anything else. An exploding wheel is the last thing you want. It should ring similar to flicking a wine glass with your finger nail if there are no cracks.
If your budget supports it, look at the CBN wheels.
Bill
Forget the ring test, there's just......
JamieDonaldson
...too great a chance that wheel with a crack is an accident waiting to happen. I also highly recommend the CBN 180 as a replacement that will never wear out, doesn't throw AlO dust, and never changes size due to dressing or wear. Its nice! ;)
robo hippy
If there is a visible crack in the wheel, get rid of it. Not worth the risk. The CBN wheels are the best out there, no contest. No risk of them ever cracking or breaking. They are spin and bubble balanced, so if there is any run out, it is your grinder, not your wheel. They will outlast, by far, any comparable $ amount of any other grinding wheel out there. No dust ever. I sweep the metal dust into my shavings.
robo hippy
Joe Pack
Thanks, all. I appreciate the information.
