I have a chance to pick up a few used bowling pins. I found a couple of internet threads re: using them, but wondered if any of you have actual experience with these? Or is this a case of trying to make the proverbial silk purse from the sow's ear?
If I could get them for free I might try turning one but I sure wouldn't pay for one. You can glue up wood and get exactly what you want and you know what the composition is.
last year or so our guild had as it's monthly challenge to turn something from old bowling pins. I turned 2 pieces from one pin. They mimicked the shape of the pin. Vases 1 from the bottom 2/3 and the other from the top 1'3. Turned out real cool. I then turned a coffee/travel mug from another. They make great conversational pieces and are marketable to bowlers. BTW no 2 pins have the exact lamination patterns inside.
When you go to turn off the outside plastic coating use a small gauge taking small cuts. Goes everywhere but worth the effort for the novelty of it.
Here are some mallets I turned from some pins in 2011 and they work fine. Some of the pins were cracked around the neck but you can tell by the sound of them when you turn the plastic off.
After you remove the plastic often the wood is often crack from the beating it has taken.
The wood inside the is a glued up from 3 or was it 5 pieces of maple with a void in the center this void is where they adjust to keep all the pins weight and center of gravity exactly the same.
To me I never found a lot wood in a pin to work with.
But I live in a place where we often find maple in the fire wood pile.
Joe, years ago I got about 2 dozen bowling pins and thought I'd hit the jackpot. But in fact it was sort of like making a silk purse out of a sow's ear, but ending up with a canvas bag with a hole in it. After spending way too much time removing the heavy plastic covering off the pins, which I did on the lathe between centers with a parting tool, only to find that the pins had voids at random places in them, I decided that it wasn't worth it.
Beware of what lies under the plastic pin coating!
