A55 Smoothing Plane
Plywood box mirror
Plywood box mirror
Plywood box mirror
OK this is a project from a piece of wood anyone else would have thrown away. I don't remember who gave me this piece. It was the corner of a solid core door. It was about 4 1/2" square, had 3/16" cherry veneer on the outside and a piece of cherry on one side and a dado on the other side. I kept it around for quite a while and everytime I looked at it thought why in the world am I keeping this. I kept thinking that maybe someday I will come up with a project for it.
Well it finally talked to me. I decided to make a mirror. I glued 2 more pieces of Cherry to the outside and filled in the Dado with cherry. I turned the mirror side and then started on the back. It was about 3 times as thick as my normal mirrors and I started to turn away some of it but then it started to look interesting. I thought what if I leave some of that cherry veneer. I did but didn't like it . then I thought what if I make a box out of it.
I hollowed it out which also reduced the weight so the mirror feels more like a normal sized mirror as far as balance.
turned a lid and then decided to add some epoxy with gold leaf in it for a little more decoration.
dug through my stash and found some more cherry and good quality plywood and made the handle.
I'm pretty happy with this one.
Re: Plywood box mirror
detail
Chuck Jones - West TN
You sure did better with this stuff than I was able to. That's an unusual and attractive mirror.
Bob Hobbs had tons of these cutoffs from a door plant in Ripley TN. I made a couple pieces with it but had lots of trouble with voids and spots where the plywood wasn't glued well.
I did have a void that needed filling.
It would be a great idea if....
mjonesrdg
I mean a super idea if the lid did not come off while using the mirror....threaded maybe??
Yes it is threaded
Re: Yes it is threaded
Stuart Johnson
Very unusual. How were you able to get threads cut in plywood? When I first saw the photo I thought it looked like you used a threaded insert but on a closer look that doesn't appear correct.
I just used the Baxter threader from Bestwoodtools. I did take small cuts instead of one big pass at full depth. I also soaked the threads in thin CA toward the end. It looked like it was threading OK but I wanted to make sure they were strong and looked good so I took the extra precaution.
Don Leydens
Don Leydens
I love when projects have more than one use. This is a terrific example and very well done, John.
Leo Cuellar
Leo Cuellar
I'm really not a fan of the plywood look in turnings. That said, John, you made that mirror look great. It is at least as good as any of your other mirrors!
what a unique idea!
You're Amazing John!
Brad Vietje
... And 1/8" Long
