Pepper Mill Recommendation
Tom Colligan
Would a stainless steel mill be preferable to a ceramic one or vice versa?
And is there a vendor who one could recommend for these.
Thanks in advance, Tom.
Tom Colligan
Re: Pepper Mill Recommendation
Dale Gillaspy
Not better pe se, just different. You will want ceramic if you are making a salt mill. Salt will corrode the stainless. For pepper and other spices, stainless is perfect.
I have purchased from several vendors in the past, but try Chef's Specialties, and as always, the usual suppliers, CSUSA, Rockler, WC, all carry about the same mills.
John Veerkamp
I prefer the crush grind ceramic so that they can be used for either salt, pepper or other spices. Also the shaft can be cut to fit the size of the mill body you created, giving more flexibility of design.
tomB
I use the Crush Grind for all of my mills now. In addition to being flexible for length, the manufacturer says they are good for 25 years. I have only used mine for 7 or so, but still as good as new, and I have a salt mill with the same mechanism.
One thing about salt mills: if you fill them up with rock salt, the salt can (and probably will) clump and solidify, and lock up the mechanism. For that reason, I only keep an inch or so of salt in it.
Ed Larson
I have a Crush Grind and a Chef Specialty sitting on my dinner table. The Chef Specialty leaks and I use a coaster under it. The Crush Grind does not leak. This is an added advantage to the Crush Grind besides in my opinion that it grinds better (more uniform grains). Anybody else experience the Crush Grind not leaking???
John Veerkamp
and another plus for the crush grind, it can be installed upside down. ie design the mill so that is sits bottom up. just turn a cap or top on what conventionally would be the bottom. No chance of dribbles on the table.
Just me?
Tony-Memphis
I must be the lone person in the workd that has had terrible luck with the crush grind mechanisms. I went through three of them last year to get one that worked, and it didn't work very well. Maybe I need to try again, but I hate to kep throwing money away.
Tony
david
I use the Crushgrind because of the design flexibility it provides. The mechanism works great. It does leak, because there is always some residual spice in the grinding parts. Don't recommend using for salt in high humidity environments--the salt will cake and clump up.
John Veerkamp
We use ours for salt and it gets very humid in Western Missouri in the summer. Never had coarse salt clump up. Maybe it'i the brand/type of salt?
david
I would guess that coarse salt would fare better than iodized table salt. Missouri summers I also guess would be better than the eastern seaboard states' humid summers. They call it relative humidity for a reason... visitors to Hawaii say it is very humid here when they first arrive--80% relative humidity is not uncommon, and my experience of humidity in places like Guam or Singapore is far worse than Hawaii.
John Veerkamp
The lower the altitude the greater the capacity of the air to hold moisture/humidity. I 've experienced sea level humidity in places like Houston and Baltimore. It is worse than here in Missouri even though altitude here is @ 675'.
