Need suggestions/opinions
Roger in MO
Roger in MO
This elm burl cut-off is about 5 x 8, 2" tall, relatively straight on two sides, the bark is fairly tight.
The back side is curved about one inch deep.
I'm considering just sanding the straight edges and the curve and displaying it standing up on the long straight edge or flat on the table with the bowl side up.
Another thought is to resaw to eliminate the curve, leaving a slab about an inch thick which would lay flat on a table.
I'll appreciate your opinion or other suggestions.
What is a good finishing material for this? The cut edges of the bark are very soft and will absorb considerable finish. The bark is tight but in natural state (somewhat dirty)
A side note, the slab is glued to the 2x6 with a paper joint and the chuck block is screwed to the 2x6. I wanted the capability to adjust the location of the bowl or maybe turn two bowls but changed my mind.
Thanks. Roger
Re: Need suggestions/opinions
Dick Coers
How about adding a contrasting wood that would have a matching profile to that back cut. It would let the burl saddle over it and then it would be flush on the back thickness. I would make it several inches longer on each side, or make it flush so you can stand it up. More of a sculptural piece, but lets you keep the thickness.
Brad Vietje
Brad Vietje
Roger,
Since you already have a rough bark edge on part of it, you could also roughen up and scorch the cut sides -- like Raffan does with some of his Mosque boxes.
In any event, I'd keep the curved back, and not flatten it.
Safe spinning,
Brad Vietje
Newbury, VT
John Veerkamp
I agree I like the curved back. Makes the piece even more unusual. I 'd leave the cut edges smooth and finished like the top side.
For the bark what I've done is to brush with a soft bristle paint brush to get the dirt off. Then I spray on several coats of satin poly. It will seal the bark and give it a little more strength without drastically changing the appearance.
Roger in MO
Roger in MO
Thanks for the replies.
I'll follow John's suggestion to leave the hollow, sand and finish. If I don't like that look, It will be relatively simple to saw off the hollow portion and end with a flat very shallow bowl.
