John has kindly put together a nice article about turning a "Recipe Calculator," essentially a round slide rule that you can use to adjust recipe quantities, convert measurements, etc. It is a great gift idea and appears to be a fun turning project. Check it out.
If you don't want to go all out and do the dovetail thing thats fun and challenging. However a lidded box would work if you leave the lid just a scosh loose.
I wonder how many of you know what a slide rule is. I wore out one and nearly a second one in Engineering College. Now days engineering calculators have completely replaced them. (I wish to H... I had one back then.)
Still have my Versalog also! I would still use it once in a while until my daughter got a scientific calculator for school. Kids today...they just don't understand significant figures...
I have my Versalog I used in college (69-73) and the book to go with it. I also have a metal Texas Speed Rule I used in high school (66-69). When I got my 2nd masters in 2006, I took them to stats class. The instructor and one navigator were the only ones who knew what they were.
slide rule that I used in the late 50's early 60's. I could not afford the fancy log-log models.
My thoughts on making a box instead of the John Lucas version is that the cook could us it as a storage container also. Probably will make both versions.
...by a universal arm? Is that the adjustable device that tracks the patterns and holds the ink pots? If so, yes I do have the whole mess, and can even throw in a bottle of India ink!!
is is a contraption with the functions of a t square and the triangles, you can use it to trace horizontal and vertical lines and any angle on between. The one I did use said "Universal" on it plus some numbers. It was great to do perspective renderings of buildings.
Let me know if it happens again. And keep a close eye on what you did to reply to that message. It showed up under my post, so I imagine you did everything right. If you or anyone else has this (or another) problem again, please send me a trouble ticket (Report Problem link above) instead of posting it on the board. That way I will be notified by e-mail of your issue and have all your cookie and operating system information. If there really is an issue, I'll need to ping our developer in Germany to look into it for us. That is very costly for me, and I'd like to be able to give him the full story of what happened, etc.
Thanks for bringing it to my attention. Sorry, no help at this time.
