Cleaning chuck
Cleaning chuck
Cleaning chuck
Dave L
What liquid---lacquer thinner, mineral spirits, etc??---should I use to clean my chucks? Thanks in advance.
Re: Cleaning chuck
Re: Cleaning chuck
John Veerkamp
I use mineral spirits. It will dissolve most wood sap residue.
Re: Cleaning chuck
Roger in MO
Re: Cleaning chuck
Roger in MO
Many farm machinery dealers stock a dry lubricant which won't attract dust if you want to lube the chuck after cleaning.
Re: Cleaning chuck
Re: Cleaning chuck
tomB
I use Dri-Slide, it is a graphite and molybdenum lubricant. Goes on wet, but the carrier evaporates and leaves only the dry stuff. I get mine at a bicycle shop. This was popular in Vietnam because it also inhibits rust.
Re: Cleaning chuck
Harry Robinette
Re: Cleaning chuck
Harry Robinette
I clean all my chucks with mineral spirits then spray them inside with PG2000 I get from Woodcraft.I also use the PG2000 on my bed ways, things slide very easy but don't creep when your working.
Re: Cleaning chuck
Re: Cleaning chuck
Geoff Whaling
Dave, I have done a fair bit of research into the recommendations of various manufacturers. Some don't seem to acknowledge that chucks need cleaning & maintenance in their manuals & on their websites.
Oneway recommend soaking the whole chuck in mineral / white spirits with 10% oil added then just blow dry (no disassembly?). I use kerosene if necessary (VM120's) but solvents are not normally required unless maintenance has really been let go, or grease has solidified or lots of wet turning. Heavy gum build up may require soaking some parts in cellulose thinners.
Most don't need much more than a spray with T9/Inox/CRC/WD40 then a wipe down before lubrication. Lube - I prefer light grease in the Vicmarc 120/140's & I do use Dry Lube / Dry PTFE in a couple of the original Nova Midi's & VM100's.
Re: Cleaning chuck
Blow out the Dust
Doc Green
For my Oneway Talon and Stronghold chucks ... when they start getting tight, I blow out the dust. In most cases, that is all that's required.
This is so simple that most turners, to whom I suggest this, just shrug it off. However, if you will blow the dust out on a regular basis, you may be pleasantly surprised.
For a chuck that has been neglected for a few months, I may flow some lacquer thinner down into the region where the scroll engages the jaw sliders, let it sit for about 59 seconds, and then blow it out. (Yes, this is a bit messy, which only reinforces the idea that you should blow it out frequently so this is not required.)
Then, every now and then, I squirt the chuck with a general purpose silicone spray. This provides a bit of lubrication and makes it turn more smoothly than it does when the metal is dry and bare.
I do Not use WD-40. It dries to a sticky mess and will gum up the works when you mix in a little dust, which is always there.
I have limited experience with other chucks, so I cannot make any further recommendations. However, I blow out my one Nova on general principles, but don't know if it does any good. It is fairly new and has never needed any special treatment.
~Doc
Re: Cleaning chuck
Re: Blow out the Dust
My vicmarcs just don't need maintenance. I did pull them apart a year ago because a conversation like this started. The dust shield on the back is very good at keeping the chuck clean. My oldest one is about 8 years old and I've never done anything to it. All my vicmarcs had very little dust internally. The Grizzly copy of the vicmarc had quite a bit more dust, probably due to the loose fitting of most of the parts.
I will agree with Doc. Don't use WD-40. I've worked on machinery most of my life and have seen many problems with users using WD_40 as a lubricant. It gums up the works. At it will totally ruin a camera. I did camera repair for a while and when someone brought me a camera that they had sprayed with WD-40 I just handed it back to them. Wasn't worth my effort to try and clean it and it certainly wouldn't work once the WD-40 starts to gum it up.
Re: Cleaning chuck
Interesting ...
Geoff Whaling
I'm in the tropics & use WD40 & Inox on my Vicmarc & Nova chucks quite regularly as a rust preventative on them. No problems with gumming up the works - well here at least.
I find the enclosed back on the Vicmarc chucks means very little maintenance (i.e. almost never) is required for the pinion & scroll gears, but the jaw slides & the scroll itself require regular maintenance. I normally brush off the dust after each session and then maybe once or twice a year remove the stop pin and wind out the backing slides to give the works a good clean. I'm not a fan of using the compressor to blow off the dust as I figure a fair bit of it is forced deeper into the works.
Re: Cleaning chuck
Re: Interesting ...
John Jordan
In 30 years I've used gallons of WD 40 on hundreds of chucks and lathes-I use it every single time I turn. The next problem I have with it will be the first problem. It is not sticky or gummy. I've had to use other things when traveling, and none work as well as WD40 IMO, but do use something. The chuck NEEDS a little lubrication as do the other moving parts. I find I only need to blow out the chuck and spray it a few times a year. I spray the bed and toolrest base and toolrest each use.
If you have a chuck that feels like it tightens, but doesn't seem to hold things tight, it is likely binding due to lack of lubrication.
It's unlikely I would be inclined to spray it in my camera, and one probably wouldn't spray it in one's firearms etc, if you have them.
Re: Cleaning chuck
Re: Interesting ...
It seems to work pretty well on larger stuff. On typewriters, cameras, teller machines and the like it's just about the worst thing you can do.
I'm a firm believer in using it on the lathe bed and tool rests.
Re: Cleaning chuck
Come on Lucas, WD 40 worked......
JamieDonaldson
...great on typewriters, for those of us who remember cleaning them! It was a fair solvent for stencil gunk and ribbon ink removal, although it really is not a lubricant. How many users really know why WD 40 was created, and it works well for that purpose. ;)
Re: Cleaning chuck
Re: Come on Lucas, WD 40 worked......
Don in Central Illinois
Removing water/vapor.
