monkey puzzle wood
lynn cranmer
Does anyone have any tips for turning a bowl from monkey puzzle wood? My first attempt was not very successful. Lots of tear out etc. Gouges were freshly sharpened and speed as fast as I felt comfortable with. TIA
monkey puzzle wood
lynn cranmer
Re: monkey puzzle wood
david
My understanding is that Monkey Puzzle is similar in most respects to our Norfolk and Cook Island Pine. If you are getting a lot of tear out, the wood must be dry. This type of wood is best turned within a couple of months of being felled. If dry, you can try to rejuvenate the wood by soaking it in a 1:4 solution of liquid dishwashing detergent and water. Aster soaking for a couple of days, remove, rinse as thoroughly as you can. After toweling off the surface water you can commence turning. I turn a tenon on a piece before soaking so I can remount the soaked piece easily. Orientation also makes a difference. Side grain orientation will produce fuzzies on two opposing sides of a piece. With end grain turning just remember to cut downhill; with the grain, not against it. If all else fails, resort to the old standby 60 grit gouge.
I frequently stabilize nasty turning.....
JamieDonaldson
...grain areas, or even the entire form, with an application of lacquer thinned with about 10% acetone. I rub it in and wipe off excess, and it functions as combination of wood sealer, sanding sealer, and undercoat for my frequent final finish of lacquer.
