Question on adding a drawbar....
I have several chucks with Morse tapers on them. They are the variety with a tang on the end of the taper. There is a hole or at least a dimple in the tang. Is there any reason not to drill a hole in the end and thread it for drawbar. I would occasionally like to run them in there head stock and I think the drawbar would be better/safer. How can I tell if the tang is too hard for this?
Re: Question on adding a drawbar....
no problem at all. The tangs are not hardened and easily drilled. At least the ones that i have done are that way.
barry rockwell
Re: Question on adding a drawbar.... *LINK*
barry rockwell
Morse tapers of all kinds are readily available for use with drawbars. Take a look. I have dealt with these people and have been very pleased.
Morse Taper Products
Roger in MO
Roger in MO
If a file will cut the taper you should be able to drill and tap it.
I've had just the opposite experience
Dick Coers
Both tapers that I have are hardened. I did buy them from a metal working surplus, quite a few years ago. I would really be surprised if the new ones from China have been hardened, but as mentioned, test with a hand file.
Essential
Bill Howatt
You've received the info on testing with a file and the hardness really is the only issue. Since it is located by the Morse taper in the headstock your drilling and tapping doesn't even have to be precisely true to the axis.
It really is more than being "better". If you don't have some pressure holding the MT into the headstock it will come loose so the drawbar isn't just better, it is essential. Normally, the pressure from the tailstock keeps the MT tight in the headstock and you have to replace this force with the drawbar.
Bill
Re: Essential
Dale Miner
Keep in mind that the taper will need to be removed at some point. If a small threaded rod is used, there may be insufficient rigidity in the rod to drive the taper loose. A 3/8“ drawrod works well for driving the taper out, but the tang on a typical #2 is right at 1/4“ and won't support a 3/8“ rod. Removal of the tang may be needed, or removal of the drawbar for driving on the end of the tang. If driving on the end of the tang, buggered threads are likely unless the threads are counter bored or given a generous chamfer.
Re: Essential
Bill Howatt
I have both my threaded rods (1/4 and 3/8) secured to the tightening knob so they unthread from the MT inside the headstock. They are all counterbored so the threads don't get damaged by the knock-out bar and that is a good point you raised.
The thing I find a bit surprising is that I never have any difficulty locating the threaded hole in the mandrel with the threaded rod.
Bill
