Lathe question.....
I made a mistake setting up my lathe. I built a cabinet that has six drawers Under the ways. the top if a piece of oak butcher block I made myself. The is a box/shaft under the head stock that is filled with sand. (about 330lbs, IIRC.) And there is sand in a tray under the butcher block and in the toe kick. All of this is under Nova DVR. the shaft is about at elbow height.
The problem is that I mounted the lathe directly on the oak top. The is only about a 1/2 to 3/4" clearance under the ways. Chips and crud accumulate under and between the ways and its a PITA to get them out. Not really all that hard, but a constant irritation. The plate that holds the tails stock onto the ways does not have much clearance and it tries to shear off stuff and it slides along and it bangs to a stop. Its a tight squeeze to try to remove them from under the ways and tough to get it out the top, even with the dust collector in the shop vac mode.
So, having said way too much, What difference would it make if I placed spacers under the lathe and raise it 3/4 or 1"? Will that be uncomfortable to have it above the elbow height? As an aside, I get some back pain and particularly a snarled muscle in my right shoulder.
