Finish for working bowl???
I have turned an Ambrosia Maple bowl that I expect to be a working salad bowl. What would you use for a finish.
Re: Finish for working bowl???
Bill Turpin in WNC mountains
Over many years the wooden bowls that were really used, I believe received NO finish. Just dried quickly after use.
david
Some kind of oil can be an advantage regardless of final "finish". Mahoney's walnut oil finish is one of several that will work.
don stephan
After filling any worm holes, I like a mix of equal parts mineral spirits, boiled linseed oil, and Pratt & Lambert 38 gloss varnish. Three coats creates a slight sheen that really shows the figure and grain in the wood. A breakfast bowl with this finish has lasted through 14 months of daily cereal and milk (hand wash, towel dry well) with no sign of water damage.
Greg Haugen
Barry, You'll get a lot of opinions on this matter. Here's the fact. Everything is food safe once it's cured. Cured is the key word. Everything is personal preference. The bowl can be left plain, or an oil finish, or a membrane finish. They're all safe once cured. Personally, I don't like membrane finished since they'll be difficult for the new owner to maintain once they get to the point of being maintained. The "salad bowl finish" from a couple of companies is nothing more than a cheap varnish. It is no different than their other varnishes but you pay more for that "salad bowl" label. Some oil finishes are a pretty good fire risk, just imagine a home owner wiping waterlox on a bowl and then throw the rags in the house garbage. I like the basic stuff. Wood is fine with no finish, so a little oil will be better yet. I like Mahoney's Finish as well as Tried and True products. Both are safe out of the bottle, no cure time needed since there's no driers or thinners. The oils will also not be to bad for maintenance since they don't have as bad of a "flash" factor like Waterlox and other oils.
The right answer is education. Educate your customer on what you use and how to take care of it.
Terry Quiram
We recently started using coconut oil for cutting boards and bowls and really like the results.
tomB
I use Howard's Feed and Wax. It is available in local stores and consists of beeswax and orange oil. Easy to apply and maintain, leaves a nice low luster
