Veritas - Innovation in Tools
Like riding a bicycle-sorta
Well I'm getting ready to go for a 24 mile ride. Need a break from turning ornaments plus need to burn off some calories. I turned 10 ornament balls between last night and this morning. The tenth one finally felt good, hollowed rapidly to an even 1/8" wall thickess. The first 9 were OK but the walls weren't quite even.
The Blue ones are cast resin blanks I got from George Taylor who got them from Alan trout. they are Acorn caps in blue resin. Pretty cool. Hollows kind of difficult. It grabbed my normal hollowing tools but the custom made Hunter tool I use works great except for the fact that it tends to cut curls instead of chips. These clog up the ball really rapidly so I had to stop after each pass and blow them out.
I'll start on the finials after my bike ride and dinner.
Re: Like riding a bicycle-sorta
Dan Jechura
Dan Jechura
wish I could do something like this. Someday I will make the time to learn.
It's just patience
Take it slow and you can do almost anything turning wise. I look back at some of the projects I did 20 years ago and wonder how I had the skills to do them. But then I think about it and realize I probably used different tools and used them differently. It went a lot slower and I probably sanded a lot more but I got it done. That's what it's all about. Just make whats in your mind. don't worry about how you get there.
George Taylor
George Taylor
The acrylic blank actually came from Eugenio Soto of Amalgum Mutts; he and Alan "conspire" together here in San Antonio. They both go through a lot of resin. ;)
Looks good no matter what John; can't wait to see the final ornaments.
Mavdad55
John, very nice. The only ornaments I have turned are the small bird houses via the late Dale Nishs book. They turned out nice, due to Dales instructions; but they typically have a large 5/8 or so hole to hollow in. Is your Hunter tool on a 3/8 shaft? I assume it has enough bend in it to get behind the neck? Or are you using multiple tools?
My homemade Hunter tool was carefully designed from flat stock to be able to reach around corners and hollow most shapes that I do on my 3 part ornaments. I do think I need to change the hook angle slightly and may possibly angle the cutter down more although I got it pretty darn close to right the first time. I may build another one shortly to see if I can over come it's few slight dissadvantages.
I do hollow the entire ornament with it. Normally I use 2 tools. A straight tool made from 1/4" drill rod and one that has a slight bend at the tip. The slightly bent one requires a good grip. I intend to bend a C in it sometime to align the cutter with the shaft to overcome this twisting motion however that requires that you ride the tool on the tool rest at the bottom of the C. On a 1/4" shank that introduces chatter so it needs to be slight.
The Hunter tool I designed gets more stable the deeper you go because the flat surface helps keep the tool from twisting. I can hollow through a 1/2" hole. Wih my 1/4" cutters I can hollow through a smaller hole but it just takes so much more time due to clearing the swarf that it's much faster and easier to open the hole up to about 1/2" One of the tools photographed below has a high speed steel cutter silver soldered to it. This one is really grabby and I don't recommend it but it does allow me to hollow really square bottom ornaments better.
Mavdad55
John thanks for the pictures of your cutters. I use a Dale Nish scraper that also has a similar flat shaft. Your carbide cutter tool would be nice to use on bird houses and small bowls I like to turn, they have a short turned in rim. I would post pictures but have not figured how to do so with an iPad. Site says pictures are to large and I have not found any photo editors that will resize the pictures.
Mavdad55
Found a tool to resize my pictures on an iPad. If I resize to 640x480 it is small enough to upload. Hope this works
Joe shelton
Hey, I use an iPad, too, and would like to be able to resize pics. What is that tool?
Joe
Dwight Rutherford
Have an iPad also. What app do you use?
Mavdad55
The iPad app is called SimpleResize
Dwight Rutherford
Looked for the app "SimpleResize", couldn't find it.
Dwight Rutherford
Got it. Works like a charm. Thanks
