Veritas - Innovation in Tools
watco wipe on poly
watco wipe on poly
watco wipe on poly
gary clarke
I poured a small amount of wipe on poly into a small, about 1/2 pint, jar and covered it with 2 layers of wax paper and screwed the top on. After about 2 weeks of use the solution formed a scum on top of the liquid. How does one prevent this? Would using a smaller container work better? ie less oxygen. Or just leave the original qt can closed, would this prevent this?
Re: watco wipe on poly
Store
Your jar upside down. The film will form on the "bottom" so that when you flip and unscrew the cap, you has useable finish. Keep doing this and you'll have this neat multi-layered jar that friends will wonder "How'd he do that?" :D
What I do is add water
david
to the container until the liquid is up to the rim of the bottle before screwing on the top. Most oils will not blend with the water and will float to the top. The key is not having any air trapped above the liquid to interact with your finish. Had problems with Waterlox gelling before the contents were used up, and after decanting the contents of the quart can into several glass food storage bottles with water added, this has not been a problem.
Re: What I do is add water
gary clarke
thanks David, I will give this a try.
Re: add water
Gary, while it may work for David with Waterlox, you'd best check with your finish maker's customer service/tech rep before you go adding water to their solvent/oil finish.
Re: add water
Dale Gillaspy
I add marbles.
It accomplishes the same thing, I can re-use them, and there isn't a compatibility problem.
i squise container in vise to keep liquid to top..
