look at all the pretty colors
Darrin Hill
never seen orange,,,
anyone got photos of other colors in a final product?
Re: look at all the pretty colors
Rob Wallace
YIKES ! ! !
Rob Wallace
I don't have pictures of color in wood, but I am taken by the home made reverse chuck you have shown...
My first reaction was "Holy Crap!" because of those exposed all-thread ends sticking-out toward the operator, and the inherent danger they create when the chuck is spun in use.
I hope some re-adjustment, installation of end covers, warning tape, or something else creative can be done to reduce the chances of possible accidents created by the unprotected, exposed ends of these support rods.
I personally would not use the chuck in this condition.
Turn Safely,
Rob Wallace
Re: YIKES ! ! !
Bill Howatt
Too scary for me too.
When I was using a donut chuck I bought various lengths of carriage bolts whose smooth, rounded head on the operator side posed much less risk of getting whacked. Since there is only small rotational pressure on the bolts, they can be swapped out frequently without stripping the square hole at the head end.
If you can't find one long enough you can use those "long nuts" that allow you to join the carriage bolt and some threaded rod in the space between the 2 pieces of the chuck.
Bill
Steven Antonucci
Since they are on T-nuts...
steven antonucci
Why not just run the threaded rod all the way down on the "business end" of the lathe? With nothing sticking out on the side you are turning on, you drop the danger quotient by 50%.
My donut chuck uses carriage bolts with a nut to hold them plumb. rounded head on the business end... If I ever remake it, I will only use three instead of four, since three point on a circle MUST lie in a plane, and it would make taking things in and out much easier.
Steve
P.S. Looks like it works pretty well?
Dick Hines
Re: Since they are on T-nuts...
Dick Hines
This is a good reason to build your self a vacuum chuck.
Steven Antonucci
only on solid pieces without voids :-)
steven antonucci
I was blowing out the dust between grits on a white oak bowl I sanded a couple of days ago, and I noticed the dust being blown through the bowl...
It is a good thing to have many tools in the bag.
I don't use my donut chuck often, but when I do, it is the only thing I would want holding whatever it is holding.
S
Darrin Hill
ah.... yeah.. that bit...
lot of my stuff has holes in it ... so vacuum chuck wont work... i;ll post photos later... also dont want to spend $ on a vacuum chuck.. this cost me less tan $3 to make cause of the nuts ...
i meant to get shorter pieces of rod, but every time i cut the rods the threads get chewed up and i have to get a tap n die set out and try to rethread the threads, and ususally wind up cross threading or just completely removing the threads.. i was using a 6 ft long piece of allthread cut with a hacksaw and the corners of the cut ground on a grinder..
anyway... i never turn more than 400 rpm... and always come straight on... its only used for cleaning a bottom off to level it .. then i will glue a glueblock on using a reverse chuck thing w/ a livecenter on my tailstock... i.e. a chuck on each end...then the bowl is perfectly aligned when i put the block on... and then next day i take it out of the donut chuck and put it in a supernova chuck.....and usually put another block on my tailstock livecenter chuck and use that as a jam on the inside of the bowl in case the jaws didnt hold the tenon on the block...
i know.. complicated and there probably is an easier way... but to me this works and is what im comfortable with (cept the long thread bits )...
just need to find shorter rods that are precut.. or get better at machining..
Harry in Beautiful Downtown Kulpsville
Darin,
Just run a nut onto the all-thread before you attack it with the hacksaw. Removing the nut should clean up the threads. Two nuts jammed together should allow you to get a good grip on the all-thread.
