Today I did turn a red oak bowl, as it was very porous, I did gave it a generous coat of sanding sealer and turned the lathe on at the lowest speed, 48 rpm.
I made kind of a knock every now and then, like the wood was talking.
Once it dried, I raised the rpm and the noise went away. Inspected everything and nothing was loose, but there is a little play in one of the slides of the Stronghold chuck.
Has anybody had something like this happen? Very curios to find out what causes it.
I've heard knocks or rattles from my 3520B from time to time. One type of a random knock, bump, or thump occurs when I have the speed turned down to its lowest possible value. That is due, I think, to the inverter being right on the fine line between running and not running, and a bit of electrical noise on the control line can cause it to turn OFF for a millisecond or two, producing the thump when it turns back ON. Increasing the speed slightly - by a few RPM - solves the problem.
I've gotten rattling sounds from a chuck, Stronghold or Talon, when I've been turning sorry wood (which is all I have) and all four jaws do not grip uniformly. It also occurs at low RPM. I don't fully understand this, but the rattle goes away if I turn up the speed a little. Of course, I then check the rattling chuck for loose jaws, screws, etc., but have never found anything amiss.
If it's the wood talking, my observation is that you'd better listen. However, when the wood talks, it speaks in a regular, one-word-per-revolution pattern which may indicate a crack or some other defect in the wood. If it's quiet in the shop and I listen carefully, it seems to say, "firewood, firewood, firewood ..."
One known issue with the 3520 is the spindle locking mechanism. It is easily accessed directly behind the switch plate. the set screws come loose and need to be tightened periodically. The noise is only noticeable at lower rpm.
Good to know the cause, and the easy fix. Thank you.
It was not the wood talking, it is solid, and it sold today, the woman said that it looked like she could hit the good for nothing on the head and hurt him, and still have a good bowl the rest of her life...
Now I wonder if I should start making background checks before selling a bowl...
And you can stop this problem if you add small drop of thick super glue. If you ever have to get the screw loose just add a little heat and it will come right out.
