First hollow form
david
When Don Derry first came through the islands doing demos ten years ago, I saw his hollowing system in action and bought one. I was in the mode of being more proficient at making bowls and chasing the Holy Grail that Bill Luce had set. My story was I was a bowl maker and would get around to hollow forms when I grew up. The advent of turning boxes a couple of years ago came close, but those were forms I could use ordinary bowl gouges to make. When Don made a return visit a couple of months ago, I decided to dust off my hollowing rig and signed up for the hands-on session. Even after all those years, the components worked well, with a replacement laser pointer that I re-purposed for use with a slide show at work. I opted to fix the laser at the point of touching wood, rather than re-setting the laser when the angle of approach to the wood changed. The walls were probably 3/16" thick, when I used a scraper attachment to smooth out the cut surfaces. Probably at 1/8" now. Wood is Silky Oak cut through a 7/8" opening, with an added ebony collar narrowing the opening so intruding fingers could not check out the inside finish. Don't think the form is quite there yet, but for a first piece I guess it passes. I found a Hawaiian quilt pattern with a stylized Kukui Nut pattern, and used a stick-n-burn film to trace around the collar. Think the pattern around the top draws your eye upward, helping to de-emphasize what I thought to be an overly bulbous form. When my wife saw the finished piece, she said I can't sell it because she gets all of my first editions. I guess it passed the acid test.
