REAL MILK PAINT
hard jaws for my jumbo jaws
I like to use my Jumbo jaws to flatten segmented rings but it's hard to get them to sit flat using the rubber jaws. I thought it would be fun to modify my 5" jaws for my Vicmarc chucks to fit on the Jumbo jaws. I just drilled a 3rd hole to match the holes in my Jumbo jaws. Had to drill the bottom hole in the 5" jaws a little larger to accept the larger threaded screws. It works perfectly. In fact it works so well I may have to modify a smaller set of jaws so that I can hold rings smaller than about 7" that this thing holds.
Re: hard jaws for my jumbo jaws
Dick Hines
Dick Hines
Now that is a great idea. Thanks for posting.
Curt Stivison
Excellent!!!!
Great idea, but . . .
Doc Green
Keep in mind that only two fairly small screws hold each jumbo jaw on the chuck. You are adding mass to each jaw and this will increase the centrifugal force acting on the screws. So, keep the RPM well below the rated maximum.
Re: Great idea, but . . .
Got ya but already thought of that. However most of the time I will be expanding the jaws into the wood ring so that will help hold them together.
Joe shelton
How flat do you get that ring to?
Joe
Not sure how I'd measure it but when I put a straight edge across it there isn't any light. Flat enough to work. I use a gouge to get it close and then switch to shear scraping to take off the high spots. doesn't take very long to flatten each ring.
For Bowl from a board projects I flatten both sides. For segmented bowl designs that require more accuracy I flatten one side and then glue it to the base that has already been trued up on a faceplate. Then I'll flatten that top side of this ring after the glue dries before installing the next ring. Takes longer this way but I get perfectly parallel lines which helps all the other elements align.
