Still groping for start-up solutions, guys. My aged Craftsman grinder has abutments for platform supports cast integrally with the housings or shrouds around the wheels, and the new Wolverine wheel dresser that came in the mail today won't reach the dam wheel.
Lowe's has a PC 8" grinder (with variable speed) that I'm strongly tempted by. Anyone know anything about this tool?
There are lots of turners using the Delta 8" variable speed grinder, which seems to work OK, although some have reported excessive vibration at certain speeds, and the stamped wheel washers occasionally have been reported to impart some run-out on the wheels. I assume the Porter Cable Bench Grinder would be similar, given its similar size and specifications.
Another grinder to consider in the same price range is now being sold by Craft Supplies - it is a Scheppach 8" slow speed grinder - one of the few remaining options for a tool of this type (and price) since Woodcraft recently pulled their popular 8" slow speed grinder due to several problems. See: http://www.woodturnerscatalog.com/p/5/-/21/149/-/5843/Scheppach-8%2522-Slow-Speed-Grinder
Good luck with your choice! If you get the PC grinder, let us know how it performs...
The local Delta manufacturer's rep told me back in January at our local Wood Show that the current Delta VS 8" grinder is the Porter Cable in Delta colours. Delta no longer has access to a large part of their old product line manufacturer's castings etc. Even the old Delta 14" Bandsaw with cast iron frame is dead.
Hard to find that Scheppach 8” grinder in stock at many vendors. Same is true of Wood River grinder WoodCraft once sold. Woodcraft dropped that grinder due to quality issues. Not sure if Scheppach grinder on a slow boat from China or has quality issues too!
Advantage of PC grinder is can buy local if have a problem right away can exchange or get a refund.
...on a grinder to be a waste of money, and most of them have been real duds. It appears that all the available 8" grinders in the Woodcraft $100 price range must be made in the same factory in China, just different colors for different destinations. I haven't looked recently, but still consider the current Woodcraft 8" grinder with AlO wheels to be the best option for the price, then replace the worn original wheel with a CBN wheel when you know that turning is not just a passing hobby.
I pretty much agree with you Jamie about variable speed, but if you want a slow speed it opens the door to more alternatives somewhat. I have the now discontinued Delta slow speed and love it.
I agree that VS is a waste of money. I got a used 6" Delta VS with AO stones with my lathe as part of a package deal. The electronics went out on the VS shortly and then it was a boat anchor. You couldn't buy the replacement part and it was out of warranty.
