Something new that's been on the back burner for a while. Turned and carved from holly, pink ivory, and ebony. the ribs are 1/8" diameter, the pupil is 1/16". A carburetor jet drill was used to drill the pieces for stringing. Any comments would be welcome.....
Keith, I am curious. It seems to me that aside from the gill and mouth grooves, the tail and head could be done with no appreciable hand carving by multi-axis turning. Was that your approach?
Hi Dennis, I think with a little planning, the entire piece could be turned. The mouth and gills could easily be turned using a pendant jig, and the tail could be turned as a larger ring, then sliced into multiple tails....However, this was my first attempt, just to see how it looked. Maybe next time it will be entirely turned.
Hi Gerald, I know a jet drill is designed for drilling brass, the particular one I used for the fish was a #71. I used a drill press, clearing the wood chips frequently to avoid straining the bit. I also use the lathe to drill with these tiny bits as well. I think drilling by hand would cause a lot of bits to break.
Ideally those small bits require much higher speeds to cut efficiently. I have and use the sets that go from #80(about .0135") up to #60. I use the Dremel with a small jacobs chuck if I can. The higher speed really helps it clear chips. Using slower speed tools like a full size drill press means you need to remove the bit from the material very frequently to clear the chips. In wood I usuallly drill by hand supporting the piece and dremel with my hands against the workbench to keep the parts moving parallel. One of these days I'm going to break down and buy one of the jewelers drill presses. I've used them and they are a dream for these small bits. Quite expensive although the Dremel drill press would probably work but it's not nearly as accurate and smooth. When you buy a set of these buy 2 sets. The bits are easy to break and you will break the one you need the most at the worst possible time.
