JET 1642. Nice lathe, bad banjo.
Craig Daymon
I got my new JET 1642 last week. Pulled out the tool rests I had for the 3520 that I previously had. Not much use since the hole for the tool rest sits directly above the cam mechanism, meaning it will only accept short stemmed rests if you want to position it at any rational position.
I looked at the JET/Powermatic lathes and it appears that this is the only lathe that features this bad design. All others have the hole for the tool rest to the side of the cam axis. Too bad. Other than that, it is a very nice banjo.
You would think someone would have seen this as an issue, especially since they bother to offset the hole on every other lathe banjo.
Aside from this, the lathe seems pretty nice and I look forward to getting lots of use out of it. MUCH lighter than the 3520 as I could easily pick the bed up by myself and carry it around the shop. Probably be adding a shelf to the bottom for extra storage and some ballast. Thinking about a shelf just below the ways with some 45 degree blocks with holes drilled through to stick tools in. Multiple holes would allow me to insert the tools I'm using in places that would not impact turning and keep the tools conveniently close. Not planning on installing the tool basket or the "safety" cage. (Personally, I'd be fairly terrified to turn with the cage installed. Way too confining. and too much opportunity to catch a tool in the cage while things are turning.)
-Craig
Re: JET 1642. Nice lathe, bad banjo.
Yup.
Greg Haugen
Yup. The banjo is the weakness. Did you notice something else? The old Jet reeves drive 12" and 14" lathes have the same banjo as the 1642. Identical. Other than the tool post directly over of the camshaft, the banjo is rather short on length once you get to the 14" range and beyond. As you pull it back, it will only contact one of the bed ways and then that creates a tremendous bounce. In a nut shell, it's a spindle turning banjo; after all it's designed to be a spindle lathe. However the 1 1/2 horse ( or 2hp), 16" swing, and sliding headstock makes it incredibly versatile. I've debated about buying a Oneway or Robust 16" banjo for turning large bowls. They run $300 to $400 depending on manufacturer. If you'd take the $2200 lathe and add a $300-$400 banjo you've got an incredible lathe. If you rarely reach the 14" swing, and stay with the shorter tool post, you'll be fine. Even manufacturers like Carter Products lists 1" tool posts as either long or short. Just FYI, if you ever use the McNaughton on it, the new standard post for the newest version of the Mark8 is an 1/8" long. Either trim it or ask Craft Supplies for a shorter post, they have several.
david
Clubmember Andy Cole has as his "portable lathe" a Jet 1642. Takes it all over the place and the 110 power is available everywhere. Someone demonstrating on it a while back broke the banjo, and Andy got a Powermatic banjo as a replacement. At a group gathering last week-end Andy mentioned that Powermatic sells the banjo as an accessory item. Don't recall the price, but those with the acknowledged less than acceptable Jet banjo can upgrade with a Powermatic banjo.
gary jarvis
I replaced my 1642 banjo with the oneway. Not only is it longer and has the offset it also clamps the tool post much more securely.
Brad Vietje
Offset (Powermatic) Banjo Not Perfect Either...
Brad Vietje
Greg,
My PM3520B banjo is plenty rugged, but the offset can be an issue for doing any close work like reverse turning a small or shallow form -- the banjo clamp wants to occupy the same space as the one on the tailstock, so I often have to loosen the bed clamp and push the tailstock back with the tail ram -- can be a PITA when reversing thin-walled or delicate objects, and I don't like to extend the ram very far out of the tailstock.
I'm also not thrilled that the banjo casting is so short! Requires long-necked tool rests, and doesn't give anywhere near as much support to a coring system as the Oneway banjo. My older McNaughton coring system (not sure if it was called a "Center Saver" back in 2002) needs a longer post to make me happy, and I wish the banjo casting was 1.5" taller.
The world's not perfect yet, so there's still work to be done ;)
Safe spinning,
Brad Vietje
Newbury, VT
