Sealer under lacquer
Roger in MO
Roger in MO
What sealer is compatible with MinWax spray can lacquer (gloss)? Both cedar and walnut are soaking up the finish. I realize the open grain of walnut will require a filler of some sort or multiple coats, sanded between, to fill the grain but am looking for alternate.
Thanks
Re: Sealer under lacquer
shellac is a good sealer under anything.
mjonesrdg
I've been using Crystalac* wood grain filler for open grain woods like walnut, oak, and mahogany. I am very positively impressed with the ease of use, and the result I get. Two coats of this takes the place of 5-6 applications of nitrocellulose lacquers. No affiliation, just very pleased. I get it from McFeely's or Rockler.
jim miles
jim miles
If it is a turning, on the walnut try wet sanding on the lathe with Linseed oil- or similiar oil or even water - it will do a nice job of filling pores, grain and small imperfections.
Cedar is kind of "oily" Linseed oil doesn't work well on it.
Lacquer does fine over LSO
Minwax Sanding Lacquer Primer
Jorge
Which is the same Minwax lacquer plus a filler, looks to me like micro cotton fiber, works very well in trouble areas, where the grain is raised or rough. I coat the whole bowl or whatever give an extra to end grain or very porous areas, let it dry thoroughly, next day sand it down t the finest grit you use and is ready to spray. If it is a piece of very sound wood, no need of filler, just dilute lacquer 70/30 with lacquer thinner, apply a thin coat, let it dry a day and then sand and spray...
Roger in MO
Roger in MO
Thanks for the responses. I will look for the products mentioned.
Roger
Re: Minwax Sanding Lacquer Primer
Hal Taylor
Jorge, curios what you sand with. Any kind of filler/sanding sealer gunks up what ever I use.
Ric Taylor
Ric Taylor
One of the reasons for using shellac as a sanding sealer is because it does not clog up sandpaper.
Ric
Bob Rogne
Can shellac be used under tung oil?
Don in Central Illinois
My understanding is that shellac can be used over or under just about anything.
Jorge
Hal,
I use 4 steel wool pieces from medium coarse to very fine (2, 0, 000, 0000) and the 220 wet dry followed by 320; the steel wool removes most of the sanding sealer and the wet dry smooths the works, it will still clog but a lot less.
Spray several thin coats. After drying, 0000 steel wool again followed by paper towels, kills the glare and leaves a nice sheen.
Mike Stafford
Mike Stafford
Very late to this thread but I use Qualalacq sanding sealer. It is lacquer based, dries quickly and can be sanded to baby butt smooth. Spray lacquers work very well over it, after all it is lacquer. I top coat my turnings with Qualalacq lacquer when I want a shine.
