How to remove gouge from older Glaser handle?
Aage Rendalen
Aage Rendalen
I acquired a Glaser handle from the 90s with the stub end of a gouge in it. It doesn't screw out, it doesn't turn around. I assume that it has been super glued in place. How do I remove the old gouge?
Re: How to remove gouge from older Glaser handle?
Doug Turner
You gently heat the gouge stub with a propane torch, grasp it with a pair of vice grip pliers and twist until free. Then pull it out. To replace the new gouge clean out the old glue and then apply epoxy and glue in place. Great handles!
I'm not absolutely sure, but recall ........
JamieDonaldson
... the tool shafts are glued into the handles with epoxy. So heating the old tool shaft with a torch will soften the grip of the epoxy, allowing the tool to be removed.
Rob Wallace
AND DON'T FORGET.......
Rob Wallace
...... that the handles are filled with shot, so when you twist-out the old gouge portion, don't tip the open end down!! (....unless you like chasing thousands of small metal balls around the floor of your shop!).
Some have advised first holding the handle in a vise or other support in a vertical position, and then heating the used-up gouge near the handle to soften the adhesive, and as said, grasping the gouge "up high" with vise grips and twisting the old gouge out of the handle. Replacement gouges are available from Glaser Hitec tools in California, and from Doug Thompson. As I recall the shanks on these Glaser gouges are not a standard size, and must be turned down a few thousanths to fit the handle.
I have replaced my older Glaser ONCE, and this technique works very well.
The handles are worth holding on to - literally and figuratively!
Rob Wallace
Re: AND DON'T FORGET.......
david
I had the red handled 3/8" Glaser that became too short to use with the Wolverine Vari-grind jig. Got a 3/8" Thompson Jimmy Clewes signature gouge, which fit nicely after using a oxy-acetelene torch to heat up and remove the old gouge. Propane torch didn't generate enough heat to remove the old gouge.
Don Evans
You can purchase MAPP's cylinders that will work on you propane torch tip. They look just like propane except for the color of cylinder which is "yellow". Lot hotter fire.
Also keep in mind that if you put it in a large metal vise that it will act as a "heat sink" which will bleed away the heat from the object. You can also use that to your advantage to protect the handle to some degree by putting the handle in the vise keeping the tool metal above the vise, clamping the handle in vise where the glue is will also slow down the action you are looking for.
Don
