Mirror #1--J. Lucas Design
Roger in MO
Roger in MO
This is my first attempt as making a mirror following John's excellent directions. Thanks John and thanks Ellis for keeping these types of materials available.
The body is from a walnut slab harvested several years ago. The handle is elm.
I need to work on my spindle turning don't I.
I bolted a crossfeed vice (H.F.) to the drill press to hold a vee fixture similiar to that which John showed in his instructions. It allows adjustment for variations in mirror body thickness.
Thanks for looking.
Re: Mirror #1--J. Lucas Design
Emmett Manley, Lakeland, TN
Good first attempt. John got me started making these mirrors last November (he does not know that) and I have now made about 45.
The most difficult step is drilling a proper 1/4" hole in the body and I have tried several methods and jigs, but I still experience some difficulty. Most of my mirrors utilize a 1/4" tenon on the handle, but if the wood is suspect, I use a 1/4" dowel to join body and handle. It is helpful to make a reverse image jig for the mirror to fit in the body -- one with the exact diameter, depth, and flatness incorporated.
Your mirrors will get smaller and lighter as you continue your quest. I have used 3", 4", and 5" mirror glass and 4" seems optimum, although the 3" mirrors are cute and can be carried in a lady's purse.
Steven Antonucci
Aside from the bead at the top, it looks great?
steven antonucci
Nothing wrong with it.
S
John lucas
Looks great. I like the little bead on the bottom. I make my tenons 3/8" I have had only one or two broken over the years if I'm really nervous a our the tenon I center drill it and install a metal dowel
Roger in MO
Roger in MO
Thanks for the comments. I'll try to post a photo of the drill fixture whenever I have the camera in the shop. The handle was turned to 3/8 dia. at the mirror end.
