plywood vase
plywood vase
plywood vase
Charles Yawn
Just finished this hollowform vase made with 3/4" baltic birch plywood. It's about 8" tall and about 6" wide. I copied the idea, design and form from a poster on the LumberJocks forum. Had to buy a new hollowing tool to turn the inside, which worked very well. Some of the plywood plys had bad tearout, so a lot of sanding and glue patching was needed. All comments welcome.
Charles
Re: plywood vase
Re: plywood vase
Jim Breeden
Excellent job Charles ! Ply is a real rassling match to turn. CA, sandpaper, CA, filler, CA, etc. :b
Re: plywood vase
Re: plywood vase
Mark Thill
Looks great, How was the the glue-up done, was it solid with layer after layer added or hollow ?
Re: plywood vase
Chuck Jones - West TN
Re: plywood vase
Great Job! I'm not sure I want to know how the glue up was done. I've already gotten a head ache trying to figure it out. :D
Re: plywood vase
Re: plywood vase
Don in Central Illinois
Great job and you HAD tl buy a new tool. What could be better?
Re: plywood vase
Re: plywood vase
Charles Yawn
Thanks for the comments, Mark.
It was a solid block of glued together plywood panels before turning. Below is an image of the bottom of the vase so you can see how the individual plywood sections were arranged. I may try a platter or shallow bowl next.
Charles
Re: plywood vase
WOW! Great!
Re: plywood vase
Brad Vietje
Hard Work!  Nice Job!
