Engraving alternative (long)
david
This is a 19-inch calabash, one of the largest I've made; turned a couple of years ago. The name of the (elementary) school is where my son went and the principal of 35 years is retiring next month. I offered to donate this bowl in honor of the retiring principal. The school trustees proposed a memorial of sorts that would list the name of the 10 school principals since the founding in 1918. I offered to burn in the school logo on opposing sides with the space in between available for plaques to be applied for each principal and the dates of their tenure. After meeting with the trophy engraving store, it became apparent that engraving on a large, curved, object was an issue. The plaques they engraved on was a maximum of 4-5-inches wide. For curved objects they pounded the flat plate on a convex mandrel to achieve a semblance of the shape the plaque was to be applied to. The goal was to have the school name on one side, and the principal's on the other. It was a lot more effort, but I volunteered to burn the school name on one side. Letters were a Times font, 96 pt., largest available on my computer, and the size across was approximately 11-inches. I used a stick-n-burn film I got from Welburn Gourd Farms. The film is run through either a laser or ink-jet printer and the good feature is the film does not promote combustion. This is the second time I have done burned lettering and I learned that it helps to have a clean line on the outline of the letters; then fill in the black with a larger burning pen; in this case a 1/16 ball point. The guide lines were drawn with a grease pencil, which is easily removed with some paint thinner. Thinner is also used to clean up the adhesive that remains after the unburned film areas are peeled off. The burning was done after the bowl was wet-sanded with Waterlox; then Beal buffed. It had been previously sanded on the lathe and soaked in Watco Danish (natural) when done a while back.
Re: Engraving alternative (long)
Finished piece
david
Showing the completed name after pyrography. The name is slightly off-center because I chose to avoid the knots on the right side.
Mike Stafford
Re: Finished piece
Mike Stafford
David, your bowl is absolutely gorgeous and your wood burning job is terrific, very classy in appearance. I love your font choice.
The bowl is a very generous contribution to the school and is filled with well wishes for all the principals and students of the past and for years to come.
Good on you my friend!
Steven Antonucci
good thing Hawaiian words are short
Steven Antonucci
The bowl is something special.
Steve
Very nicely done David, and thanks.......
JamieDonaldson
...also for the tip about the nonflammable tape. This might be a solution to the problem I've had with engraving Beads of Courage labels on pieces made for that program. Round objects can't easily be laser engraved, and my hand painting, like my hand writing, leaves much to be desired as a presentation! >(
Re: Very nicely done David, and thanks.......
Barry L Elder
Kudos to you David, for a great bowl and the time and effort to develop your skills. This piece will surely be appreciated by many, many people!
Re: good thing Hawaiian words are short
david
Some names can be longer than a line on a typewritten page! Often the word is a compilation of other words. In this case Hana means "work" and hau'oli means "happy". So school of happy work.
Don Leydens
Don Leydens
Gorgeous piece, David and thanks for posting the pyro ideas. Well done on all counts!
George Van Beynen
Thanks for taking the time to post this David. The bowl is exceptionally well done. Your information will be put to use, you have discovered a great system to produce excellent results.
Please note...
david
Pine is a very soft wood. You will have different results using pyrography on hardwoods. As Andi Wolfe shows in her demos, doing a test piece with various patterns using the pens you have available on the wood you plan to use is a very good idea.
Thanks for the comments. I like it when an idea comes together...
Hal Taylor
Your bowl and burning is treasure for the school. Your sharing the info about the pattern transfer material you used is a treasure for the rest of us. I'm sure the gourd people will be inundated with orders from woodturners.
Credit Juergen Schleicher for suggesting..
david
that I look up the source for this material in the first place. Juergen visited my shop a couple of years ago and had a lot of suggestions and resources that I was able to put into effect.
Mike Rubes, Cary, NC
Hi David,
That is a beautiful piece and a very clever idea! I've been asked a few times if I could burn a saying or name on a bowl and I've always said no because I didn't really think my "penmanship" was up to the task. That's a great idea and will be something fun to play with.
I hope all is well.
Mike
Still putting the shop together in Cary, NC!
Hawaiian Wheel of Fortune
charlie belden
I'd like to buy a vowel Alex - an "e" please.
Bing-Bing-Bing-Bing-Bing-Bing-Bing-Bing-Bing . . . Bing
Rob Wallace
Re: Hawaiian Wheel of Fortune
Rob Wallace
Charlie....
.....to my knowledge, Alex doesn't sell vowels.... (he only helps choose categories for a certain amount)...
I suggest buying vowels from "Pat"..... :D
Rob
Re: Finished piece
Juergen
David
Outstanding job!! The clean outline and consistent fill makes piece really shine.
Juergen
