Rubber Stopper
Rubber Stopper
Rubber Stopper
Kelly M. Robison
Hi All, Working on a project for MBH. I need several rubber stoppers like I use when turning Salt Shakers. I had several extras left over from my pepper grinder kits and now need more. My local woodworkers store don't sell them separate. Any ideas where I can buy some; I need at least 6 each. I can't use cork stoppers because of the clearance. The brown rubber stoppers work great; and I don't want to admit to the "War Dept" that I can't find them.
Thanks again for everybody's input.
Kelly in Port Orchard
Re: Rubber Stopper
Re: Rubber Stopper
Henry (Raleigh, NC)
Kelly - I'm not quite sure exactly what type of stopper yo are seeking, but my local (excellent independent) hardware store carries a variety of stoppers (both size and material).
Looking online I would be surprised if you could not find what you need at a scientific supply house. A number of both local and national options came up in my browser under the search term "scientific supply company." Of course for an inexpensive item like this the shipping/handling fees might seem very expensive!
Henry
Re: Rubber Stopper
Re: Rubber Stopper
Ryan
Go to www.aftosa.com and search for rubber stoppers.
Re: Rubber Stopper
Re: Rubber Stopper
David Walser
Craft Supplies USA carries a "rubber bung" for use with salt shakers. The bungs fit a 1" diameter hole. Copy and paste the following link into your browser: http://www.woodturnerscatalog.com/p/4/-/12/54/-/5268/Turners-Select-Rubber-Bung/rubber+bung
I'm sure other turning supply houses carry a similar item.
Re: Rubber Stopper
Re: Rubber Stopper
Jim Breeden
Kelly, Have you tried your local Ace Hardware? The one's we have in Albuquerque have one long aisle full of those "specialty" parts drawers, down both sides. I always go there first.
Re: Rubber Stopper
Re: Rubber Stopper
Don Orr
Try searching for Chef Specialties and then search for pepper/salt mills or grinder kits. I believe they sell what you are looking for individually. That is if you are looking for the rubber plug or bung that goes in the bottom of a turned salt shaker-not a grinder/mill.
Re: Rubber Stopper
Plastic plug alternative...
david
A while back I was making miniature salt and pepper sets (flat work) and was looking for something to plug a recessed hole in the bottom. I came across a company (http://www.caplugs.com) that sold all kinds of plastic caps and plugs. Helps that they will send you free samples. I needed a size to fit just right into a 7/8" dis. hole and had the right amount of tension to fit tight yet be able to remove by rocking back and forth. At the time, I thought they did the job. Trouble is, there is a minimum order, so I have a ton of them left over. Also may have some issues with the plastic deteriorating over time and becoming brittle. This was a while back, so don't recall all the details. Loss of brain cells, etc.
