My Big Red knob died ...
Doc Green
...so I replaced it with this:
Here's what it used to look like:
Now I have knob envy.
~Doc
Re: My Big Red knob died ...
Pete in Holland, MI
Doc -
Yea.....that will work, but takes effort to find in an emergency. E-stop buttons are large for this reason.
Do some research in Grainger, McMaster Carr, or check for the industrial electrical supply houses in your area for a push-pull switch. They're not that tough to find.
Pete
Bill McWhirter
Graingers sells the switch. They can look it up with with the number printed on the original. Cost about $12 as I remember. Local store had it in the next day.
You do not have to replace the red button. The actual switch snaps on the back of the big red pushbutton. Old one comes off with the push of a small screw driver. Comes as both a normally open and normally closed. You want the normally closed.
Re: A wider shot
Doc Green
Here's a wider shot of the front panel. The big red bar is the OFF switch. To the lower left, slightly less convenient, is the green ON switch. Both are momentary contact push buttons in a circuit patterned after a magnetic motor starter, with the relay and the whole bit. I have a kick bar emergency off mounted just under the frame all along the front of the lathe as well.
Actually, I seldom used the big red button. In fact, I'm surprised it died after only five years of "seldom use."
Pete and Bill, thanks for the info on getting a new switch. I like the idea of not having to buy another big red knob.
~Doc
Rob Wallace
Rob Wallace
My "Big Red Knob" also died about a year ago on my Jet 1642 after many thousands of on and off pull-push cycles.
In my case it was the actuator head and not the contact block that went bad. Mine was a 22 mm push-pull emergency stop button (not the twist-reset type) made by Telemecanique. I managed to find several of the exact replacement units (identical to the OEM parts used on Jet/Powermatic lathes) being sold at good prices on eBay (Business and Industrial). The two switch units I got were complete, in that they had the both mushroom-head pushbutton (push-pull action; with all new mounting hardware) and the contact blocks, all brand new, in the factory packaging. It was an easy repair and the lathe works as new. I did not want to pay the $65+ price via Jet/Powermatic parts or from Grainger, etc., and bought two brand new switch units (one for repair and one for on-hand parts) for about $ 33 (including shipping).
Don't overlook eBay as a possible source for OEM replacement parts - just check the part numbers carefully, and know what you are ordering. I would not be happy with using a toggle switch in this application.
Rob Wallace
Don Leydens
Don Leydens
I keep seeing folks with this same problem (me included). Seems to be a recurring problem with the Powermatic.
Rob Wallace
For those with the same problem
Rob Wallace
For those of you experiencing the "on-off" switch malfunction on Jet or Powermatic lathes, you might consider replacing the Mushroom Push-Pull switch - which is a relatively simple job.
The part number for the Telemecanique Red Push-Pull Mushroom actuator used on Jet and Powermatic Lathes is:
Telemecanique ZB5AT4 (40 mm mushroom head; Look for Push-Pull and NOT Twist-reset)
The part number for the contact block (at least on the Jet 1642) which is a Normally Closed switch is:
Telemecanique ZB2-BE102
I hope this helps!
Rob
Re:  Thanks, Rob!
Doc Green
VERY helpful.
I checked mine for numbers and the only thing I found was on the body of the switch itself: ZBE-102. And the switch is normally closed.
Lathe is PM 3520B.
Chuck Jones - West TN
Should the red button be used for ON/OFF?
I have received conflicting expert opinions on whether one should use the red (emergency) button for normal on/off, or use the speed dial.
When I first got my Jet 1642 I used the speed dial because the red button seemed like, well a red emergency button. Some folks told me my hair would fall out and my teeth would rot if I continued to do that. They were correct about the hair. Others have said I would wear out the emergency button if I used it all the time.
I had some electrical schooling about 55 years ago and I can wire a house, barn, shop, and a few other thing, but I know zilch about this variable speed apparatus.
All expert opinions appreciated.
Should the Red Button be Forgot?
When I got my Stubby 1000, it came with a remote on-off switch, but also has a red emergency kill button. Everyone I've spoken to has been uniform that the kill switch is there for emergencies only, and if the manufacturer wanted it used as the default off button, they wouldn't have supplied a regular off switch. After all, why use 2 switches when one will do quite nicely?
Kind like a fire extinguisher, hopefully you don't use it but it should be tested once in a while.
YMMV
PS: In 11 years I've never used the Red Button except to test it once or twice a year to make sure it works in case I need it.
Mike Stafford
Re: Should the Red Button be Forgot?
Mike Stafford
I was taught the same thing about the red buttons when I got my Stubby.
I have never used the red button on my Stubby except to test as you said Mark.
I don't know if the red button on the Powermatic works the same way. As I recall there are three controls on the Powermatic. The red button serves as the on/off. Below that is a toggle switch for forward/reverse and below that is a dial knob for increasing RPM. I don't think there is an emergency switch on the Powermatic per se.
Re: Should the red button be used for ON/OFF?
Not sure why anyone would say that. If you look at the schematic for the VFD on my Powermatic this is simply and on/off button. Won't hurt a thing other than possibly mechanically wearing out the switch. I turn my Powermatic button on and off a million times a day with no problems. (I told you a billion times not to exaggerate so much). No seriously, every time I need to stop the lathe I use that button. It won't hurt the electronics at all.
Now there is a good reason especially for beginners to not use that knob. It's very easy to forget and not turn the speed back down when you finish one project and start another. Put that 16" unbalanced bowl blank on the lathe and start it up after turning a pen at 3000 rpm and you get a lot of excitement really quick.
However most of the time in my shop I turn the lathe off to inspect the piece or some other function and want the speed to be the same when I start over. Consequently my Red Button gets a lot of use. When I was turning on a 3520B at Arrowmont they moved the red button from where it is on my 3520A. I must have pushed the black knob that opens the belt changing door 30 times during the week trying to stop the lathe.
My question was intended to be...
Does it hurt anything to use the variable speed control to start and stop the lathe during normal use?
Re: My question was intended to be...
Chuck The one thing I can't answer is does it hurt to let the lathe sit for any length of time with the variable speed knob turned down to zero. If there's no voltage the motor then I would say it won't. If there is then I wonder how long it can sit like that. If I think about it I'll try to measure mine tomorrow. Of course if you turn the lathe off using the red knob at the end of each session then I think it would not hurt it at all. That's just my opinion of course and you know how opinions are. :)
Sergio
The manual of the Jet 1642 states that the red knob is to turn the lathe on and off.
The manual for th Powermatic 3520B calls is on/off button.
On the Jet the technical service said to me that since the red button do not take the power out of the inverter, in fact the red display is illuminated and indicates 00 RPM even when the red button is pushed, it is a good idea to disconnect the power from the pug to prevent a damage to the inverter in case of tunderstormsor similar. I had a dedicated switch which shut the current off the lathe completely.
Harry Robinette
Harry Robinette
I just put the upgrade on my General the guy at Automation Direct said to install the E button between the VFD and the motor. Don't use an E button that will shut the VFD off at speed,use the stop button on the VFD for general on/off. The E button will stop the motor from running for an emergency. Also I read somewhere that a three phase motor should have all 3 ph wires switched not just 2 like I've heard some guy's do it.
Just what I've heard and read.
Sergio
Thank you. My is a simple 20 amp 220v double pole switch located before the lathe plug. In practice it is like turning off and on the electricity to the lathe or better it is like unplugging it without removing the plug and I use it after having pushed the red switch on the lathe.
Here is a link to the wiring diagram of the switch:
https://www.platt.com/CutSheets/Leviton/CS220-2W%20Wiring.pdf
John Jordan
You can use either red button on the Stubby, as John pointed out they are just on/off switches. On a Oneway, maybe others, the red switch will shut down the lathe for a period of time.
I would not use the variable speed control for on/off, its made to change the speed of the lathe, will wear, and would cost more to replace. The switches rarely go bad, and if they do, you can get them from the manufacturer, or Grainger. Mostly if they fail, they have gotten dust in them. Although they are fairly sealed up, a blast with the air hose, and tapping it lightly will often solve the problem. All lathes these days use standard industrial switches.
John
John Jordan
I should point out that what I said about the Stubby switches applies to older lathes. I believe Bill only has one red switch on the current lathes.
John
