Elm
Dan Jechura
So has anyone turned Elm before? How does it turn?
Dan J.
Elm
Dan Jechura
Dan J.
Like wood! Which elm?
Re: Elm
Mark ravensdale
Turns great (if a little course) living in the UK I turn it quite frequently, I have some lovely burr elm just waiting for the right project (been drying around 7 year now) does tend to move some what while drying though!!!
Re: Like wood! Which elm?
Mark ravensdale
That should be wych Elm shouldn't it ;-)
Re: Elm
Dan Jechura
I was just told it was Elm. I guy gave me 6 crotch's
Re: Elm
Mark ravensdale
Lucky man!!!
Re: Elm
Don Stephan
No doubt he was splitting the wood by hand!
Had an opportunity to turn a bit of american elm last summer and was very pleased. It's hard, so sanding takes some time, but the grain pattern is wonderful.
Re: Elm
Lan Brady
I have turned a lot of American Elm. It is a bit stringy, but it finishes great. The grain pattern is unbelievable.
Lan
Very good Mark, that is one of them
Dick Coers
All elms are course grained, some much prettier than others. I've turned one crotch piece, and the feather wasn't very deep. I prefer to sandblast it to really accent the course grain.
Re: Elm
Bernie Weishapl
I turn a lot of elm as it plentiful around here. Elm is pretty grainy but it does turn nicely and finish nicely.
Re: Elm
Keith Newton
Most elm is medium to hard density, not too coarse, nor any pitch or gummy problems, and one of the highest tensile strengths, which means it isn't bad at splitting, so you could try something adventuresome, where you utilize the distortion of it warping, if you turn it to completion while wet, or green, then letting it do it's thing.
Damn, did I just put all that into one sentence?
Re: Elm
John Veerkamp
A great turning wood, smells like pi## when turning, I guess that's why the common elm around is called pi## elm. It spalts readily and as others said has a mind of its own.
One of my favorites
Chuck Jones - West TN
I have turned a lot and I have a lot lying around. Like all wood it varies from tree to tree depending on the sub species and where and how it grew. The bigger the tree the better the chances of getting some really great colors. I don't know enough about the different varieties to be helpful. I do know one that is common on my place is winged elm.
Here is a piece that was a royal screw up, so I decided to have some fun with it. Dyed it with Marine boot dye and steel wooled it back. It's becoming our favorite candy dish.
Re: Elm
Dan Jechura
Thank you for all your help. I am going to try turning a bowl tonight.
Re: Elm
clay foster
When I lived in Texas, there was an elm called cedar elm, because the wood looked like what we called cedar, which was actually juniper. It was hard, tough, and sandpaper resistant, but striking grain and color, and worth the effort. Here's a picture of a cabinet I made from cedar elm. It was also resistant to Dutch elm disease.
Re: Elm
Mike Foster
That's a beautiful cabinet Clay!
Re: Elm
Lyle Jamieson
I use elm a lot, it is great, finishes beautiful, and is forgiving in the drying process. It has a barnyard smell when wet. Many, most of my figurative sculptures are elm because of the strong grain character and I need very large trees to work with. See them at lylejamieson.com
I like it!
George Taylor
Re: turned some of the elm
Dan Jechura
Well I cut one of the crotchs in half This is what I started with
This is the ruffed out bowl 8 " ish by 2" ish.
An here are some small bowl I make out of left overs. They are 3" ish.
I have turned alot of wet wood latlly but this is really wet. I did not notice any smell while turning so this most not be P*** Elm.
None of this is ready to sand so I will put them to bed in the microwave for a while.
I am open to comments.
Dan J.
Dan Jechura
I was told American Elm
