Carver help
Carver help
Carver help
Dale Gillaspy
I am in the market for a micro-motor carver. I already have the Foredom, and it just doesn't put out high enough RPM for what I need. I have been looking at the RAM brand from Treeline, but CSUSA sells the Optima 2 for about $70 more. Both are pretty comparable to one another, just wondering if anyone had any reviews?
Thanks,
Dale
Re: Carver help
Re: Carver help *LINK*
Check out this carver's supply outfit
Micro
Re: Carver help
How does this unit work for piercing?
Re: Carver help
No Direct Experience
I do buy for the supplier and have had very good response from them + excellent product quality. I do have a friend who bought their Mic-Mot in the link and has been happy with it so far for carving.
For tight control in piercing, it's my impression that the hyper speed turbine units are best. I bought my Turbo Carver II from them and have been quite pleased although Memsahib keeps asking me if I plan to go to dental school. :D
Re: Carver help
woodcarver supply
Darryl
the micro carver will turn up to 45,000 and is less than $200. Dixie Biggs uses it over the fordom.
Re: Carver help
Re: No Direct Experience
Dale I don't have experience with that model but have played with quite a few similar. They are lighter than Dremels and easier to use. In my experience they won't do a very good job of piercing. There's very little difference in the speed of a Dremel at 23K and those at 45K. Cutters at this speed will still follow the grain so it takes a light touch and lot's of patience to do piercing. When you use these side by side with a 400K grinder there's no comparison. The 400K grinders are like writing with a fine pin.
For carving fine details those pens are wonderful. Easier to use than Dremels or Dremels with flex shafts. I also tried air grinders that run at 56K. They work pretty good as well but again not anywhere close to the ease of the 400K grinders. The 46K and 56K grinders are really just a small step up from the Dremels as far as ability to pierce. They are easier to hold and work with for detail carving than Dremels but may not be as powerful if you use larger cutters. Of course that's where the Foredom's come in.
Re: Carver help
david
In for a penny...and all that stuff. Opted to order a 320K NSK handpiece and regulator from J Paul Fennell. Cost almost as much as the unit Mark got, but am counting on a product that Paul uses and sells. Would have been nice to have another air source in the separate compressor, but already have one that works well for now. Hope I made the right choice...
Re: Carver help
Re: How does this unit work for piercing?
Mike Foster
I have the gamut of what you gys are talking about. I have a dental version of the ram, a brushless handpiece about the same size and weight as most of the others I've seen. I think they are all about equal in effectiveness and smoothness of cut. They are great for general carving and even detail work, but not so great for piercing. Again, I have dental handpieces, but they are similar to the NSK, but have a head at right angle to the handpiece. I am so used to these, that I just see no need to purchase a nsk. Some day I'll try one to see if I like it better. I also have a Weecher, Foredom, slow speed air driven dental handpiece and several die grinders and use them all. What I use depends on the task at hand. Sometimes all of them for one piece. Again, for piercing, like John said, go with the NSK or the like.
Re: Carver help
Mike When I took Binh Pho's class we used both styles of hand pieces, the straight and the 90 degrees. It really depends on how you hold the tool as to which one is the most comfortable. I'm used to the pencil style and felt more comfortable controlling it but after long hours your hand gets crampy. The 90 degree didn't seem to cramp my hand as bad and probably with practice would be just as controllable for me.
If your really interested in piercing call Binh Pho and J Paul Fennel and talk to them about the tools they use and the pricing. They do far more than any of us have some very valid opinions on what tools work.
Re: Carver help
Thanks for the input, guys!
david
Sorry if I pretty much hijacked this thread. As mentioned above, I ordered a high speed NSK handpiece and an air regulator from J Paul.
Re: Carver help
High Speed need specials burs?
charlie belden
I've heard, or read, that the really high speed carvers need specially balanced burs. Recalling that Kinetic Energy = mass x velocity^2, going from 40K to 400K rpms kicks up the KE by a factor of 100. Granted, the burs don't have much mass, but . . .
The cost of the high speed carver is just part of the total cost. I bought a router. I have twice its cost in router bits.
Re: Carver help
Not Special *LINK*
"Standard" 1/16" shank dental burrs are fine. There are 8 listed at the link at $4.50 each, but you can get them for free from your dentist!
"Free" he said? Yeah, most don't bother autoclaving the burrs after each use; their cost for the burr used on/in your cavity is figured into the price for your filling and they buy them in quantity. Ask and you may receive.
Burrs
Re: Carver help
Free Burs
charlie belden
Many people have trouble throwing stuff away - and dentist are no exception.
Twenty five plus years ago, when I was making jewelry, I asked my dentist if he had any old dental burs I could have. He smiled, left the room for a while and came back with a small box (3"x3" x 1" tall). Inside were small blue paper "envelopes", each containing six burs of a particular type, in different sizes. There must've been 300 burs in that box, each sharp and shiny.
"I sent these out for sharpening and shortly thereafter high speed steel burs came out and they worked much better. Couldn't throw the old burs out so I kept them. Now they're yours.
"You mean there were people who sharpened these little burs? Were they midgets by any chance?" I asked with tongue in cheek.
"As a matter of fact, my sharpening guy was a midget." I was told.
After you've paid your dentist $5k or more, you should be able to ask for used dental burs - and old dental tools - scrapers, explorers, etc.
Don't hurt to ask.
Re: Carver help
Every Time
I've "had work done" I come home with the burrs he used. The hyper-speed burrs are carbide. At $2 a piece, it doesn't pay to send them out for regrinding.
