Bowls & Boxes
Roger in MO
Here are some bowls and boxes turned since Christmas
The large ash bowl is about 9" dia x 3" tall
The strait side ash bowl is about 6 x 2 1/2
The platter/bowl, also ash, 7 1/2 x 1 1/2
The elm burl box (?) is about 5x5. It was a Christmas present and I don't recall exact size.
The small box on the right is elm. That tree was cut last spring but seems dry and so far has not changed size or shape. Size is nominal 3x3
The other box is 2 1/2 D x 3 tall. It also is ash but has a hedge insert on the top. This box represents a whole bunch of "redesign opportunities" I started out by turning the wrong detail in the top. (thus the hedge insert). Then the skew decided to go off on a tangent which resulted is a body diameter reduction. Since the bottom detail on the top was already established the diameter of the top ended smaller than envisioned. The chunk of hedge was one from a dead stump that I cut maybe 5 or 6 years ago and has been in the shop since then. Yes, it was very hard!
Thanks for looking.
