Have a question? Ask Woody!
Question about long spindles
Joe shelton
Don't even have a lathe yet, and I'm already trying to trick it out. Is it possible or reasonable to use two banjos with a very long tool rest?
Thanks,
Joe
Re: Question about long spindles
Doc Green
Yes. Both possible and reasonable.
Steven Antonucci
And easy
steven antonucci
Long spindles tend to be lighter and thinner than say, bowls.
I bought a length of scrap bar at the salvage yard and tapped a hole in it to fit my interchangeable tool rest post. The other end gets propped up with a 2x4, but if I was using it often, I'd just make a wooden banjo.
Steve
Yes
Jorge
Joe,
two banjos and a stiff wooden board make a perfect tool rest, we did use white oak and cut the profile of the spindle right into it, instant duplicator! use a bedan of parting tool to 3stablish all the lowest points and then waste away using a spindle roughing gouge final clean up with a skew... My boss made a perfect stairway spindle in 7 minutes.
Re: Yes
Thanks, guys. Now I won't have o retakethe
I once made a five foot stair rail out of Cherry and Walnut for a large boat, but it takes more than just two banjo's.
When the need for a really long....
JamieDonaldson
...set of 4 post bedposts in a single piece arose several years ago, I mounted my General 160 longbed tailstock to tailstock with my Stubby, and bolted them together with a 2x4 to keep the length from "stretching." Turned 4 walnut posts 84" in length without a problem!
