I have a big 18" roughed turned poplar bowl. that has a crack down one side. Other than that it is sound. I hat to lose the bowl. Could I fill the crack with inlace? I have never used inlace. The bowl is 1 1/'4" thick.
I think the Inlace would work but I would use epoxy and some kind of filler,saw dust brass shavings or the Inlace stuff .I just think the epoxy will help hold the crack better.
...filling such a large crack in a roughed piece as a "permanent fix." The wood will always continue to move with moisture changes, so if it can be safely turned I would stitch the crack when completed.
Having used a lot of Inlace, it does not move the same as the wood. A gap like that will possibly open up just a hair in the future. Epoxy also doesn't move the same but does have more strength and bonding. You can color epoxy with india inks or oil paints.
If you can use a Dremel or something to hollow out the inside of the crack so the Inlace or epoxy will form a sort of tenon when it dries it will not fall out. the wood may move and tiny crack may show but it will close during part of the year. This is kind of the same problem you have with breadboard ends on tables, they stick out during the winter and may be too short during the summer depending on when the table was assembled.
You could even undercut them so the tenons are like dovetails. I don't know if this will hold permanantly but I'm not sure the stitching will either. Wood can be really strong when it want's to move.
First you need to stabilize the crack so that your piece will not fly apart when you finish turn (assuming you want to do this, of course). A butterfly patch is both decorative and functional. George Nakashima, when he was living, made signature pieces using large slabs of wood where a butterfly patch was a prominent part of the overall finish. Ancient Hawaiians used several types of patches including the butterfly type. There are templates available for cutting the hole and butterflies from several wood varieties available. The patch can be part of the wall thickness or it can be through the wall completely. Contact me offline for information on where these templates and ready-cut patches can be obtained.
Dick, I use West System for large repairs. You can get small cans; there is no guessing about proportions and it does have a slight flexibility. You can mix any filler with it if you want. West also sells a tube of black additive which is really a nice addition if it suits.
