NIP Help?
NIP Help?
NIP Help?
Ed Larson
My stepdaughter in Kona took down three 100' Norfork Island Pines and call to see if I would be interested. I said yes. Limited by flat rate boxes I suggested getting 5-6 inch diameter logs 10 inches long with the knot pattern near the center of the log. It turns out there was no small diameter logs and so I got three "pancake" logs 6" think (10, 8 and 7 inches in diameter) with the knot pattern near the center as shown in the picture.
What are my options?? I would think end grain bowl are out. What about end grain boxes, with the knot as a feature?? Any help appreciated.
Re: NIP Help?
Re: NIP Help?
Dick Coers
Why is the bowl option out? Looks like you better let it spalt for a while to get better color.
Re: NIP Help?
Re: NIP Help?
Ed Larson
Dick
It just seemed like a shallow end grain bowl would not work. After writing I did thing of just using the center portion for an end grain bowl that was say 6" X 6" and then get end grain boxes/bowls out from the outer portion. I'm open to all suggestions.
Re: NIP Help?
Re: NIP Help?
david
Ed:
You can leave the pieces in the weather to develop spalting, or you can turn them now. The golden color is the result before any spalting starts. Have attached a photo of what is possible with the branches roughly in the middle of the piece. This is a natural edge taking advantage of the dimples on the perimeter above the branches. You could turn a flatter shape with the knots in a star pattern. It all depends on how your shape cuts into the branches that go from the perimeter to the center of the log.
BTW, 6" diameter lodgepole pine sections makes great poi pounders...
Re: NIP Help?
Mike Stafford
Re: NIP Help?
Mike Stafford
Ooooh, David that is pretty!
Re: NIP Help?
Don Leydens
Re: NIP Help?
Don Leydens
Yea, that's pretty alright!
Why not give one a try, David?
Re: NIP Help?
Re: NIP Help?
Mike Rubes, Apex, NC
Hi David,
I really like this one! The bowl itself is great, but I really love the rim treatment. It gives the impression of a big flower. Very nicely done!
I hope all is well in Hawaii. Spring is slow to arrive here this year. Most trees are just starting to bud and the high today is just 40F! Chilly for this time of year.
Take care,
Mike
Re: NIP Help?
Re: NIP Help?
Mike Gibson
Of course you could always make a teapot. :D
or a hollow form.
Michael.
Re: NIP Help?
Re: NIP Help?
Ed Larson
David, thanks for enlightening me about the possibilities of making a thin walled shallow bowl from these logs. I guess the best thing to do is put one on the lathe, turn it wet and see what develops. I will place one outside in the dirt and keep it wet and see if it spalts.
Re: NIP Help?
Re: NIP Help?
Joe Dickason
Or a salad bowl. Pine from Florida, not turned too thin. Was pretty punky by the time I got it. Not wonderful, but better than I expected when I started. About 16" diameter X 3" tall
Re: NIP Help?
Re: NIP Help?
phillip medghalchi
Ed, put it on the lathe and then go with the flow. It'll tell you what to make of it. what have you got to lose?
Re: NIP Help?
Re: NIP Help?
phillip medghalchi
Mike you think you can make them any prettier? Those are gorgeous.
