One of my first bowls
Allan W
Allan W
Turned this bowl from a block of Box Elder. The confused grain on the sides made it a little difficult to turn and hard to get a smooth finish on the sides.
Re: One of my first bowls
Rob Wallace
Rob Wallace
Very nice job Allan!
You chose a challenging wood for one of your first bowls! Box elder is notorious for having bad tear-out. It is one of the softest of the "soft maples" and it seems that if you even look at it wrong, it tends to reward you with end-grain tear-out.
Part of the solution is to make very light finishing cuts (or shear scrapes) with very sharp tools. If that doesn't work, you can always try the lacquer or shellac technique to stabilize the problematic fibers. Hand sanding with the grain with the lathe stopped also helps remove swirl-marks and scratches from tools or aggressive, low-grit number abrasives that leave their marks when the lathe is on.
This one's a keeper! Hang on to several different pieces you've done, especially your early ones, and after gaining more experience and practice, you'll be able to compare your work over a period of time, and see how you have progressed as a turner.
Keep that lathe spinning and TURN SAFELY!! Welcome to the addiction!
Rob Wallace
Terry Scott
Hi Allan
Nice job for a first bowl many on this site including myself would have struggled to get one done this good after 20 or more
One question was this turned cross grain or is it end grain
If end grain there lies half the problem
Recently I went and picked up a wood turners gear from his work shop for a widow to sell on here behalf .I couldn't believe it there were hundreds of half finished bowls all end grain
With a bit of research I found out from his son he had been turning for 30 years and that it was only a month before he died that he found he should have been turning cross grain
Some of the bowls had dig ins like a crater
Cheers
Allan W
Allan W
Thanks for the support. So far I have turned about four bowls from the box elder log I received free from a local arborist.
Al
Allan W
Allan W
This was from cross grain. I learned about this after I tried to turn my first bowl from a piece of dry box elder that was end grain. It was impossible to get the sides thin enough and the bowl gouges kept grabbing the wood.
I received the log from a local arborist and it is the first one that I have cut up.
Thank you for the suggestions.
Al
Jim Pugh
Hi Allen, nice first bowl. Some Boxelder trees have streaks of red in them that make the wood worth messing around with. If your boxelder is still in log form you need to get it cut into slabs and band sawed into rounds so you can rough turn them and let the wood dry before finish turning. If what I'm saying doesn't make a lot of sense to you I suggest that you find an area wood turning club and go ask lots of questions. Hopefully you'll meet at least one experienced turner who will take you under his wing until you have more experience. Most of us have learned what we know the hard way - by making lots of mistakes. And this is not to say that it isn't a good way to learn but on the other hand, if someone can tell you why you need to cut up that log as soon as you can, how to do it and what to do with it later you'll be way ahead of the game.
Tell us where you live and we can locate the nearest wood turning club for you.
Brad Vietje
Re: One of my first bowls *LINK*
Brad Vietje
Hey Allan,
I agree with Rob -- that's a keeper, and a very good bowl for a beginner!
This is a very nice shape, especially for an early bowl. Most beginners make clunky bowls with more vertical sides and a sharp "corner" between sides and bottom, instead of a smooth curve from rim to foot, so you are way ahead of the curve on this one! Keep up the good work.
Boxelder can be difficult, but also rewarding; the good news is it sands well. It is an excellent wood to learn all about bowl turning, and often easy to get if you live where it is common. If you learn to identify Boxelder as a live tree, keep an eye out for them on steep river banks, or growing amongst rocks or up against buildings or fences in developed areas. They can form magnificent burls -- especially when stressed or when the roots are "squeezed" between things like rocks and such -- which are very nice for turning. Where I live these are common weed trees, so when cut they are often just pushed aside, and most people are happy to have you remove them. They tend to hang onto the dried seed cases until Spring, so you can often see them in damp areas from afar due to the tan-colored seeds, which makes them easy to spot in Winter.
http://www.treetopics.com/acer_negundo/index.htm
...and here:
http://thelifeofyourtime.wordpress.com/2011/01/27/random-plant-boxelder/
Boxelder also tends to form multiple trunks that are very weakly connected at the base, so they often split apart in big storms, or after a big wet Spring snowstorm from the weight of the snow. Since they tend to form root burls when they get big, keep an eye out for these -- they're "money trees!"
If you live where it gets good and cold, sometimes you can turn these soft woods like Boxelder or Basswood when frozen for a cleaner cut, or as others have written, stiffen up the wood fibers with something to harden the wood before final cuts.
Safe spinning,
Brad Vietje
Newbury, VT
Boxelder Info Here
Jim Barbour
Jim Barbour
Nice bowl. I like the fact that you have done some detail work on the rim -- that usually doesn't come around for the first hundred or so bowls. Let me echo the advice to find a club in your area; as my grandfather used to say, "experience is a dear teacher, but only a fool has no other". I've put a link to the AAW page where you can enter a state and find chapters near by. Keep up the good work, keep us posted with pictures of how it's going, find a mentor and, most importantly, be safe.
Local AAW Chapters search page
Allan W
Allan W
I live in Madison, WI. I checked out the site link and there is a chapter here in Madison. Thanks for the link. The rim detail was added after I messed up and did not have the bowl clamped tight enough and it came off and ended up with a dent in the rim. I didn't want to discard the bowl so I looked at my tools to find out what I could use to remove the dent without removing to much wood.
Al
Jim Barbour
Jim Barbour
Al, we call those mishaps "design opportunities". Sometimes they are the way the turning gods tell us an area needs work!
