A wood-drying conundrum
Mike Foster
Here is a problem we don't often face in turning, and one that I anticipated as I started down this journey with one of my weird math based pieces. I am working with wet cherry, but rather than the normal bowl/vessel dimensions or wall thicknesses, this piece wants to be on the order of 2-3" in cross section and is turned from a block of face grain cherry about 12" in diameter. I want to carve the outside surface of the form with a pattern, then use some techniques I learned from Jacques Vesery to do some dry brush painting on the result. The real glitch is that carving the cherry is soooo much easier if the wood is wet. As you may guess, the problem is that wood that thick wants to check on the end grain, as the surface dries much faster than the interior. I actually have the piece shaped, and have started the surface carving, but tonight got my first check. I have been storing the piece in the pile of wet shavings (from the turning) while it is not being worked on, and that seemed to work pretty well. I think that the time I have spent working on shape and beginning the surface carving has now been enough to give me problems on the sides with the end grain.
So I hit the one check with some CA, and then sealed the rest of the endgrain with some shellac. I think this will keep things in check (pun intended) while doing the surface carving, but wonder about how the piece will behave later in life after carving and painting are done.
So now I am wondering if the microwave drying thing may work for me to help get the piece to a point where it won't check. Now I realize most wont have tried microwaving something this thick, but maybe someone has. I also wonder if I kept the endgrain sealed while microwaving if that may be a better idea. Perhaps it is better to just seal the piece well and hope for the best. I really hate to do that though, because if it checks badly, the piece would become worthless and I would hate to put a huge amount of work into a worthless piece of firewood. I really considered using a piece of kiln dried, or air dried (if I could find either) 12/4 cherry for this piece, but carving kiln dried wood is a whole different, less pleasant, experience than carving wet cherry. I may end up resorting to this if I have to.
Any thoughts? Anyone try anything like that? Just for your interests sake, the piece I'm attempting would be similar to the one shown below. This piece was turned and carved from a very well air dried burl (I've had the wood for at least 15 years). Wet, face grain cherry is a whole different ball game.
