Cutting Kitchen floor
Lynn Reedy
I am in the middle of a kitchen remodel and I have to remove the kitchen floor.
We are installing new three-quarter inch red oak flooring, unfinished. I have a island
and base cabinets I must remove to run the new floor under them. I am removing a
1/2 inch plywood, 2 layers of vinyl and one layer of luan. This totals one inch thick.
When done I will be down to the subfloor. I can remove the floor no closer than about
6 inches from the kick board under the cabinets. That is as close as a saw can get.
Hope everybody understands. I know others have encountered this, I need suggestions
as to how can I cut the floor out directly next to the kick boards. This will keep me from
removing any cabinets. My thought is a 4 1/2 side grinder with some sort of a saw blade.
Any suggestions will be appreciated.
Lynn Reedy
Soddy Daisy Tn.
Re: Cutting Kitchen floor
Rob Wallace
Re: Cutting Kitchen floor *LINK*
Rob Wallace
Lynn:
You need a specialty saw, something like that supplied by Crain Tools. This company manufactures all manner of tools for the flooring and carpet installation trades, and they are quality tools. If you can identify what you need, the tool(s) might be rented at a local rental business, or purchased from a place like Seven Corners Hardware in Minnesota ( http://www.7corners.com/ ) or at amazon.com. See the link below and the range of tools that Crain manufactures just for this purpose.
I certainly hope that you do not try to jury-rig something to do this task. Blades flying around without proper guarding and control features might represent at best a trip to the ER for some stitches, or worse, to surgery for major repair. This situation requires a specialty tool, and there are such beasts designed for this purpose.
Work safely!
Rob Wallace
Crain Tools Specialty Saws Web Page
Lynn, I have been considering the same problem. I looked at the Crane tools and it looks like a winner if it will fit in your toe kick, but I looked at it on Amazon and it sells for $309. That's a lot for a totally specialized tool You are unlikely to get much use out of after this project. I would look into renting such a tool. Might even be able to find a local contractor that would make the cuts for you.
Another thought is to use a Oscillating multitool, like a Fien or Bosch. Actually there are a bunch of them out there. I bought a rebuilt battery powered one by Bosch and have worn it out and then bought a corded Bosch one. this is a tool I bought on a whim almost as a joke and have found fifty times as many uses for as I thought I might. I think the Fien is a fine tool but still expensive. The Bosch version ranges form about $99 to $169. If you are patient and will to lay on the floor to make the cut you could make this cut. Depending on how much you have to cut it would take a while, but You would end up owning a tool you might get a lot of use out of later. There are a number of offset cutters that would work for this. I would put something in place like a strip of plastic laminate or even cardboard to keep from chewing up the toe kick, or you could chew it up and cover it later. I'm cheap, I would be pretty happy to spend two or three hours making this cut and saving $150 and getting a nice tool.
The biggest disadvantage to these tools is the cutters are outrageously expensive. They range from About $8 to more than $20.
Harry Robinette
Harry Robinette
I used my Fein Multi-Master to do my floors worked great.
HeatherAinAK
My local rental company had the specialty saw for doing this. Might be alot cheaper to just rent one for the day.
Heather
Lynn Reedy
Do you think a fein multi master can cut
layer of luan totaling 1 inch?
Chuck Jones - West TN
Can you cut and remove one layer at a time?
Harry Robinette
Harry Robinette
Lynn
I don't think the Fein would have a problem,you might be able to rent one.
jim 9 miles
Angle grinder with a blade- NO !
However with a 36 or 24 grit sanding disc might accomplish the same thing, but slower and safer and cheaper.
Are all of them under the cabinets?
I think you would have to remove it a layer or two at a time. At least it wodl be easier that way and probably faster.
Are you sure all the layers go under the cabinets? That would mean the cabinets have been removed and re-installed over and over. Or have the cabinets been replaced that many times?
I like the idea of renting the specialty saw if you can. If you buy a Multitool look at the blade attachment. Not sure but I think the Fien uses proprietary blades. The Bosch and some others will accept anybody's blades. This can be huge.
nathan murphey
Do you have a biscuit jointer? Without the guide you can trim to about 1/4 inch and the blade will extend to 1/2 inch or so. It also works great if putting a hardwood floor down and don't want to take off the base moulding just trim to the correct height.
