Proper chainsaw maintenance?
Steven Antonucci
steven antonucci
Reading below about the chainsaw buy/rent thread spurred a question in my mind? Exactly what is the proper chainsaw maintenance routine for a saw? (I know I don't do it... mostly because I don't know what it is?)
I know how to file the teeth to resharpen a chain. I mix oil and gas a gallon at a time, and try to run down the gas so it isn't sitting in the saw. Occasionally, I blow out the filter with compressed air and dig the gunk out (some of it).
What else is there to do?
Steve
Re: Proper chainsaw maintenance?
You've covered the high spots of ......
JamieDonaldson
...regular maintenance, but occasionally the bar also needs some attention. Remove and clean the gunk and shavings out of the chain/sprocket cover area on the body, same with the slot in the bar and nose gear. Inspect the bar edges to maintain them flat and not worn by the chain, and file or grind flat if necessary. Some life can be added back to the bar by flipping it top to bottom with each chain replacement, and don't overextend the life of the chain when it shows wear, because it can be really ugly if it should break during use!
Rodney
Well Steven, one thing that you may remember from a previous discussion and which you wrote that you already do is turn the bar over at each sharpening of the chain to even the wear on the bar. Probably also a good idea to follow the manual's recommendations to set the mixture and idle speed screws at least once a year or possibly more often if you use the saw a lot.
Steven Antonucci
(I have other ideas)
steven antonucci
just waiting to see what else comes up...
Changing a spark plug?
Does anyone do any chain brake maintenance? (Pulling the sprocket cover to see what is underneath?) (my brake broke, or I never would have... but after replacing it, I will add it to the routine because if you see what is in there, it probably deserves some attention)
When you you replace the drive sprocket? (if ever?)
Etc...
Steve
check the drive sprocket- replace if worn
I seldom change a plug but do ....
JamieDonaldson
...occasionally pull them to check gap and wire brush off carbon buildup. An older or heavily used saw( I have several of each!) sometimes needs the muffler/spark arrester cleaned or replaced, or even eliminated altogether without noticable effect. That can be a difficult to troubleshoot reason for a saw that is hard to start and run.
Galen Vetterick
With my old Mac you needed to remove the sprocket cover and remove the bar to clean out the oil lube feed hole and the one on the bar. At the same time I cleaned up the brake band cause the oil and dust buildup would not allow it to stop dead or hold the chain well when you started it. The chain tightener screw needed the fine oiled chips cleaned out so it took little effort to adjust during use. Always kept the bar tip sprocket greased more often then I had to put in bar oil. Then most of what has been noted.
robo hippy
I cheat, I take it back to the dealer about once a year for a tune up.
robo hippy
Alan Zenreich
Alan Zenreich
Steve,
Just curious... what are the manufacturer's recommendations for maintenance of your make/model saw(s)?
Alan Zenreich
Alan Zenreich
When all else fails... read the instructions!
For example, on my Stihl MS260, the user manual has a maintenance chart that includes intervals for the following items
- Complete machine
- Throttle trigger, trigger interloc, Master Control
- Chain brake
- Pickup body/filter in fuel tank
- Fuel tanks
- Chain oil tank
- Chain lubrication
- Saw chain
- Guide bar
- Chain sprocket
- Air Filter
- Anti vibration elements
- Cooling inlets
- Cylinder fins
- Carburetor
- Spark plug
- All accessible screws and nuts (not adjusting screws)
- Spark arresting screen in muffler
- Chain catcher
- Cylinder
In about 12 or more years of owning my first Husky I did none of the above except blowing out the air cleaner filter every season and replacing it maybe once during that time. I never reversed the bar, changed the sparkplug. I left gas in it all year round and mostly used alcohol gas once my local gas station changed.
I certainly won't argue that you should and maybe I'll follow that advice on my new one. The old one has been to the shop once for a tune up when it just wouldn't run properly but that was after 12 years. It now runs great. I bought the second saw only because the first one died when I needed it most and couldn't wait the day or so to get the other one fixed. I do use my saws all winter although not nearly as often.
I have checked the bar for wear and think I filed a tiny bit on it once. It has never had a problem with not cutting true as long as I had a properly sharpened chain on it.
Steven Antonucci
What, but not how...
steven antonucci
I ran out to look at my manual, and it had a matrix similar to yours, but not a whole lot of information on "how to perform" this maintenance. I used the time to pull the spark arrester from the muffler and clean it (now that I knew it was something to do...) and I assumed that a wire brush was going to be a viable way of doing that (I think it was?)
Assume that these dialogs will add 1-2 steps to everyone's yearly routine...
Steve
Steven Antonucci
Pretty much ditto...
Chuck Jones - West TN
mostly I follow the JLucas Plan
But if you read the first eight pages of warnings in the manual, and the first three paragraphs in each section, you won't have to worry about maintenance because you'll be too scared to use the darned thing.
My main saw is a Husky 455 pre-2000 vintage. Very heavily used on the farm, on disaster response, and now for harvesting more blanks than anyone needs. Minimal maintenance. Cranks on the fourth or fifth pull every time. My second most heavily used is a Stihl 009L similar story. It's even older.
Maybe we worry too much about these things. If it breaks I'll probably either take it to my dealer like Robo Hippy suggested or throw it in the dump and buy a new one.
In the good old days
Jorge
before ethanol, to put away the saw for a good while, the advice was to fill it, so no air was on the tank to prevent condensation.
Now is this the opposite empty the tank, fire the saw so it is totally empty. Ethanol is bad fro the gas lines and carburetor it just kills them, keeps getting more and more water.
General maintenance, is to disassemble it and clean all the gunk after each use, I blow the crud with compressed air; flip the bar and now and then file the edges of it with a flat file, lube the nose bearing, blow saw dust from air filter and everywhere else and occasional replacement of the spark plug. Besides the routine filing of the chain.
Keith Tompkins
Keith Tompkins
Steve, if you are mechanically inclined, setting the mixture is the most critical aspect of the engine's longevity. I can tell you how to do it , but it does take some experience. New plug at the correct heat range and gapped, clean filter first. There are three adjusting screws on a typical saw.(.some new models are plugged, preset at the factory.) Warm up the engine and set the idle speed so it doesn't stall, then turn the low-speed adjusting screw inward slowly until the engine speed slows. Then, turn it outward until it regains idle speed..too far, and the engine will run rich, and begin to misfire. Then, high-speed adjustment...hold the trigger wide open, and turn the high-speed screw in slowly until engine speed begins to slow...then back out until engine runs smoothly. Too far...black oily smoke (rich). Whenever you hear someone tell you their saw's engine seized up....it was probably set too lean, which causes overheating.
Keith has been "tuning" his bikes again!
So what does proper chainsaw maintenance allow?
Galen Vetterick
A lot of sawing abuse! I had a little McCulloch 310 before the 610. The hardest test on the little guy was to cut on probably half the 500 old creasoted oak railroad ties I laid in three terraces walls. Think I used three chains and they even cut a lot of granite ballast rock embedded in most. Original bar and a lot of gas, oil and chain lube.
Lots of smoke and the occasional sparks too!
Keith Tompkins
Re: Keith has been "tuning" his bikes again!
Keith Tompkins
You got that right Jamie! My old Honda has two sets of ignition points, which must be set precisely, then individually timed; one set for cylinders 1 and 4, the other set for cylinders 2 and 3. Then, set mixture and syncronize four carburetors....Oh yeah, then road test..wahooooooo :D
Stihl saws
Mike Brazeau
We had a Stihl support person speak a few years back at our Golden Horseshoe Guild. The best tip I picked up was to use Hi test gas and to use the Stihl oil as it has fuel stabilizer in it. Like Steve, I use a one gallon gas can.
Exclusive use of the "new" Stihl oil .........
JamieDonaldson
..also doubles the life of the warrantee on new Stihl saws, according to my dealer.
