...Grex AOS368 for about $100 at Vince's Wood N Wonders.
Haven't pulled the trigger yet, but I believe the 105 degree angle would help get into some close places. The cfm rating is higher than the one you are looking at, but all ratings may not be created equally. Just another option if you haven't already seen it.
I've been using the $50 angled electric drill/sander that Vince sells for a year or so now and it's holding up fine. Just have to take it a little easy and keep the dust blown out frequently. Tell you how I know... it started making noise and I took it apart, found it packed with dust and grease mixture, cleaned it, read Vince's advice, started blowing it out like he says and everything has been fine since.
I suggest you try one of the Grex sanders before you buy it if you can. They are tremendous air hogs, and with the 2" pad, you don't get much sawdust for the effort. You may be wanting a fine detail sander, and for that it is fine. But if you need to cut out a little line, or chip out in small bowls, they aren't good for that. I really like my Metabo electric, but wish it was a little more friendly to grip. The large diameter body fatigues my aging hands pretty quickly.
I have both and they lay in the draw most of the time. I use a Necko(?)angle drill from Vince for the smaller stuff. I use the late Bill Neddow's High Speed Angle Grinder with his adapter and a speed reducer
for a router. You sand at about 4000 rpm with a 3"or5" disc this is what I use for the larger stuff 16" to 25".
The air is to noisey and the exhaust blows dust everywhere,I also seam to eat disc.
I highly recommend the Grex!. I bought my second one after going through 2 of the HF RO sanders. The Grex is much quieter than others I've used, but all that is relative.
